Hi Guys,
My NA8 aircon makes high pitch screeching noises on cold starts, once it gets warmed up its fine, aircon is still cold. Sounds like a belt or fan issue but I don't know.
I just had the car serviced, so I'm just wondering if this could last until the next service or if I need it addressed before something catostrophic happens to the aircon?
NA8 screeching air-con
- CQYD
- emexv
Re: NA8 screeching air-con
99.9% sure it will be the belt. They need to be very tight. Check it for wear and if it's ok tighten it up.
Mark
Mark
- CQYD
thanks,
Will see what I can do to the belt after work.
- MackTheKnife
If you have any silicone spray handy, it might be worth giving the belt a spray too while you're there.
The belt will have dried out over time, the silicone spray freshens it up a bit.
The Mx-5 says of the driver, 'I am a maverick who plays by his own rules' and 'I appreciate a vehicle with low running costs and reasonable insurance'
