...seriously.
Hjt wrote:Not debating anything.between se and sp parts, just confirming a change in the turbo will help, a few people use Nissan turbos, I dunno the part numbers though.
Lokiel wrote:Hjt wrote:Not debating anything.between se and sp parts, just confirming a change in the turbo will help, a few people use Nissan turbos, I dunno the part numbers though.
The GT2560R is the turbo you're thinking of, it's a stock Nissan turbo and the one FM recommend for MSM owners since it has similar response to the IHI turbo but able to develop about 60HP more.
This is the turbo I plan to upgrade to eventually since FM found the T28 too laggy. Novice1 mentioned that this is not the case at all so is it possible that Garrett have corrected this since FM did their tests? This may be the case since FM tend not to update their product lines much once they have a product in place (development co$t$ money).
Novice1 wrote:Check out http://www.turbobygarrett.com/turbobygarrett/
From what i can see there are 10 t28turbos all good for 300 hp.
Maybe the one Fm tested might have been laggy, but mine certainly isn,t.
Plus i have no idea which one of the 10 mine is.
cheers novice1
