Novice1 aka Rons car
- Steampunk
Re: Novice1 aka Rons car
After the mountain run lats night....
I'm all set for high-boost next time Mr.Novice1
- Novice1
Car is at the tuners. Looking forward to getting her back in a weeks time and no more black soot over driveway.
If it makes 180 atw i will be stoked.
Cheers novice1 aka ron
- Novice1
I am stoked as one of the guests on Top Gear said it goes like a stalked nun.
Now if it would only stop bloody raining here in qld. The wallet is empty but I am one very happy man.
Cheers Novice1 aka Ron
- MINX
Now Ron, dont go testing it on the street - come along to Lakeside and take advantage of legally using all that grunt!
- Novice1
Lakeside in the rain.......its not going to happen.
- Novice1
Quick update after forged internals. Torque 378.4 NM, Power 256hp. Tuner reckons there is another 10-15hp in her with advanced timing.
After several runs on high boost.......it doesn't need any more HP
Scary quick.
Cheers Novice1
Scary quick.
Cheers Novice1
- MINX
Yummy
- Novice1
MINX wrote:Torque 378.4 NM, Power 256hp
Yummy
And ues I will be at the next track day.
cheers novice1
- timk
That's good, the next track day is at QR so a lot more run off if you happen to need it. I can imagine a high powered MX-5 being pretty scary to drive at Lakeside if it is your first event!
- Novice1
saboteur wrote:That's good, the next track day is at QR so a lot more run off if you happen to need it. I can imagine a high powered MX-5 being pretty scary to drive at Lakeside if it is your first event!
Plan is to run it on low boost first couple of sessions. If I feel comfortable with the track then I will switch to high boost.
Solid power dude. What boost is this on?
- Novice1
charlie_91 wrote:Solid power dude. What boost is this on?
High boost I think is 18. Low boost no idea. Will check with my tuner, idle is a little higher than I would like.
Novice1
- zero00
Sounds great!
Look forward to seeing you at QR May 21st next!!
Roger D-SUNSHINE COAST
- Novice1
Decals added to car today. The pictures don't do them justice.
http://img220.imageshack.us/img220/8421/dscf0506y.jpg
Novice1 aka Ron
Novice1 aka Ron
- Novice1
Users browsing this forum: No registered users and 316 guests
