Novice1 aka Rons car
Steampunk
Re: Novice1 aka Rons car
Postby Steampunk » Sat Mar 03, 2012 4:05 pm
After the mountain run lats night....
I'm all set for high-boost next time Mr.Novice1
:twisted:
Novice1
Postby Novice1 » Thu Mar 08, 2012 8:03 pm
Car is at the tuners. Looking forward to getting her back in a weeks time and no more black soot over driveway.
If it makes 180 atw i will be stoked.
Cheers novice1 aka ron
Novice1
Postby Novice1 » Thu Mar 22, 2012 6:31 pm
I am stoked as one of the guests on Top Gear said it goes like a stalked nun.
Now if it would only stop bloody raining here in qld. The wallet is empty but I am one very happy man.
Cheers Novice1 aka Ron
MINX
Postby MINX » Thu Mar 22, 2012 6:38 pm
Now Ron, dont go testing it on the street - come along to Lakeside and take advantage of legally using all that grunt!
Novice1
Postby Novice1 » Thu Mar 22, 2012 7:01 pm
Lakeside in the rain.......its not going to happen.
Novice1
Postby Novice1 » Fri Apr 20, 2012 2:46 pm
Quick update after forged internals. Torque 378.4 NM, Power 256hp. Tuner reckons there is another 10-15hp in her with advanced timing.
After several runs on high boost.......it doesn't need any more HP :)
Scary quick.
Cheers Novice1
MINX
Postby MINX » Fri Apr 20, 2012 2:55 pm
Yummy :mrgreen:
Novice1
Postby Novice1 » Fri Apr 20, 2012 3:10 pm
Yummy :mrgreen:
And ues I will be at the next track day.
cheers novice1
timk
Postby timk » Fri Apr 20, 2012 3:54 pm
That's good, the next track day is at QR so a lot more run off if you happen to need it. I can imagine a high powered MX-5 being pretty scary to drive at Lakeside if it is your first event!
Novice1
Postby Novice1 » Fri Apr 20, 2012 4:01 pm
saboteur wrote:That's good, the next track day is at QR so a lot more run off if you happen to need it. I can imagine a high powered MX-5 being pretty scary to drive at Lakeside if it is your first event!
Plan is to run it on low boost first couple of sessions. If I feel comfortable with the track then I will switch to high boost.
charlie_91
Postby charlie_91 » Sat Apr 21, 2012 3:53 pm
Solid power dude. What boost is this on?
Novice1
Postby Novice1 » Sat Apr 21, 2012 8:19 pm
charlie_91 wrote:Solid power dude. What boost is this on?
High boost I think is 18. Low boost no idea. Will check with my tuner, idle is a little higher than I would like.
Novice1
zero00
Postby zero00 » Sat Apr 21, 2012 8:36 pm
Sounds great!
Look forward to seeing you at QR May 21st next!!
Roger D-SUNSHINE COAST
Novice1
Postby Novice1 » Sat May 12, 2012 6:33 pm
Decals added to car today. The pictures don't do them justice.
http://img220.imageshack.us/img220/8421/dscf0506y.jpg
Novice1 aka Ron
Novice1
Postby Novice1 » Sat May 12, 2012 6:35 pm
