145,000kms original timing belt
luke__
Postby luke__ » Tue Mar 20, 2012 10:01 pm
I bought my car on 144'000ks and i've added about 600ks onto that. I asked the person i bought the car of if they did the 100,000k timing belt and she hadn't so now i really need to change it. I don't thing she had serviced it in a while so what exactly do i need to change so my car doesn't blow up. :O
toppertee
Re: 145,000kms original timing belt
Postby toppertee » Tue Mar 20, 2012 10:26 pm
Timing belt kit with gaskets
Belts
Water pump
Oil, filters and fluid replacement
Basic 100km service.
Pretty tuff little motors.
Brake check etc
Good luck
JBT
Postby JBT » Tue Mar 20, 2012 10:32 pm
Which model MX-5 :?:
luke__
Postby luke__ » Tue Mar 20, 2012 10:37 pm
Its a na8. Any idea roughly what it would cost?
JBT
Postby JBT » Tue Mar 20, 2012 10:45 pm
$1,000 +....depending on whether you do the work or you take it to a mechanic.
luke__
Postby luke__ » Tue Mar 20, 2012 10:49 pm
Ill have to take it to a mechanic :( hopefully its not too much. I'm fine with $1500 if i have to.
CQYD
Postby CQYD » Wed Mar 21, 2012 2:26 pm
might as well do the seals too while you are there, they are probably worn by now
bootz
Postby bootz » Wed Mar 21, 2012 6:37 pm
what seals? Crankshaft?
JBT
Postby JBT » Wed Mar 21, 2012 6:50 pm
Camshaft and crankshaft front seals.
Postby manga_blue » Thu Mar 22, 2012 7:34 pm
toppertee wrote:Timing belt kit with gaskets
Belts
Water pump
Brake check etc
Good luck
x2. Fluid replacement should mean engine, diff, gearbox, brake, clutch AND coolant to give it all a nice fresh start for you.
luke__
Postby luke__ » Sat Mar 24, 2012 5:07 pm
Anyone recommend an oil or just what the mechanic has that's right for the car? I might be able to do oil myself. How hard is it?
jules
Guitar Hero
Postby jules » Sat Mar 24, 2012 5:20 pm
Don't forget timing belt tensioner and isn't there an idler bearing in there too? Been a loooong time.
Jules
Postby NitroDann » Sat Mar 24, 2012 5:36 pm
Muffler bearing mate, not 'idler'.
Basho
Postby Basho » Sun Mar 25, 2012 12:09 pm
Timing belt invoice Gold coast Mazda done in Nov 2011 , all the bits, all the bucks,two pages.
http://imageshack.us/photo/my-images/839/gcmp2.pdf/
http://imageshack.us/photo/my-images/685/gcmp1.pdf/
:beer:
Russellb
RIP Nov 2014
Postby Russellb » Sun Mar 25, 2012 8:18 pm
Basho wrote:Timing belt invoice Gold coast Mazda done in Nov 2011 , all the bits, all the bucks,two pages.
:beer:
Thats what we charge in Canberra but We do ALL the water hoses at the same Time
maybe we are to cheep
My ClubmanRebuild
MX5 SE Rally car is HERE :)
