NitroDann's Long Awaited Garage Thread
charlie_91
Re: NitroDann's Long Awaited Garage Thread
Postby charlie_91 » Mon Mar 12, 2012 8:59 pm
fabrication looks good. But v band will always be the death of me :( never again
Postby NitroDann » Mon Mar 12, 2012 9:01 pm
Why?
plohl
Postby plohl » Tue Mar 13, 2012 12:52 am
great work dann!
plohl
charlie_91
Postby charlie_91 » Tue Mar 13, 2012 7:23 am
Biggest pita to line up and clamp by urself.
rxmx
Vehicle: NA6 - Turbo
Postby rxmx » Tue Mar 13, 2012 10:31 am
charlie_91 wrote:Biggest pita to line up and clamp by urself.
Also if you don't clamp it tight before welding, and if you put too much heat into it you will warp the flanges and have leaks. There are New style v-bands that have a male female locator, much much easier to line up...
rxmx,
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
Postby NitroDann » Tue Mar 13, 2012 10:51 am
I have the ones with the locators. They are nice.
Postby NitroDann » Tue Mar 13, 2012 6:04 pm
Thought Id add, now Im home from work, that in the above picture you can see that that V band is a male V band.
You can see the lip on the inside.
Postby NitroDann » Sun Mar 25, 2012 7:42 pm
Bump with pics from just now of all the gear waiting the last few bits to arrive in the post. The water lines and return.
I cant wait for results,
Postby NitroDann » Sun Mar 25, 2012 7:47 pm
And here is the much requested photo..
Enjoy,
Old Dude
Postby Old Dude » Sun Mar 25, 2012 8:13 pm
looks good Dann, how is the sound?
Dale 8)
MX 5 2001 Grace Green
NB8B
Postby NitroDann » Sun Mar 25, 2012 8:29 pm
I only ran it once because it was on during fit up. Sounds awesome. :)
Not as loud as one would guess due to the turbo.
wazman
Postby wazman » Mon Mar 26, 2012 3:23 pm
you should should put a flex bit in that dump pipe somewhere ! my whole exhaust is tight and uses every stock hanger and STILL the turbo to manifold nuts wriggle loose :(
just about to buy the flyin miata nut locking system....... its the engine twisting on and off throttle thats causing the probs.
Also like the flyin miata and greddy turbo kits im gunna make a bracket that holds the dump firm with the engine. These generally bolt onto the tow side gearbox bolts and then exhaust clamp around the dump.
Your crazy running only one muffler ! ha ha ha im a drifter and even i run two! maybe im getting old! Sick fab work man.
ilovedrift.com
Postby NitroDann » Mon Mar 26, 2012 3:30 pm
Cheers man.
Budget build, we will see how the exhaust goes, my car has had no issues in 2 years with no flex and it twists hard enough to have broken 3 engine mounts in that time.
If it turns out to want a flexi join one can be added later, the one muffler, well its turbo, so its not that bad, this is not a daily we are talking about here. :mrgreen:
Ive told him that he might want a resonator added later, but all that increases the cost. This setup will work, and produce some serious mumbo, and be reliable. You would be surprised how cheap this setup is, the people who have PMd me sure were.
Postby NitroDann » Fri Mar 30, 2012 1:33 pm
MASSIVE thanks to Joe for being so patient.
If I were building 5 setups at a time it wouldnt be so bad because Id buy 5 of everything, but its the little bits and pieces that count. Theres about 30 seperate components just involved in the water and oil lines for example, and then theres a full set of brand new studs and locknuts, and then gaskets etc etc. Lots of running around.
Note the house keys for size reference of the downpipe. Im actually really happy with how professionally presented it all looks.
Thanks,
JOJO82
Postby JOJO82 » Fri Mar 30, 2012 3:15 pm
Holy crap that is one massive downpipe :shock:
I know I have said it before but I will say it again, thank's for building this turbo setup Dann...
The workmanship in this is absolutely A1 and I can't wait until we get this on the car... :lol: :lol:
