Bilstein Front Shocks Question
myredmx5
Postby myredmx5 » Fri Mar 09, 2012 9:53 am
Does anyone know why the front bilstein shock have an L shaped piece of metal at the bottom?
Re: Bilstein Front Shocks Question
Postby hks_kansei » Fri Mar 09, 2012 9:59 am
If I remember correctly it's a bracket to hold an ABS sensor (or something to do with ABS/brakes anyway)
Postby Regie » Fri Mar 09, 2012 5:37 pm
Yep abs sensor wire
myredmx5
Postby myredmx5 » Sat Mar 10, 2012 9:05 am
Thanks guys. Looks like if I cut them off I could save a few grams?
Jace
Postby Jace » Sat Mar 10, 2012 12:04 pm
really?
Steampunk
Postby Steampunk » Sat Mar 10, 2012 1:55 pm
myredmx5 wrote:Thanks guys. Looks like if I cut them off I could save a few grams?
Jace wrote:really?
Ditto
:roll:
Do you drive around naked, only bringing your licence?
Those two tabs would weigh less than a singlet, plus when you go and sell it, you've removed any NB owners out of the market.
myredmx5
Postby myredmx5 » Sat Mar 10, 2012 3:07 pm
1red5 wrote:Those two tabs would weigh less than a singlet, plus when you go and sell it, you've removed any NB owners out of the market.
So do all NB's have ABS?
gussy
Postby gussy » Sat Mar 10, 2012 5:42 pm
No.
Postby Regie » Sat Mar 10, 2012 8:20 pm
NB8B onwards so mid 2000ish
wun911
Postby wun911 » Sun Mar 11, 2012 12:21 am
If you shave it off is it considered unsprung weight savings yes no? if you cut the spring shorter would that be considered un-sprung weight savings, maybe that would be more worthwhile?
Sometimes I'm not sure if the cable ties I use to hold my abs sensor weigh less, than the flimsy bit of metal because the really thin cable ties arnt long enough to wrap around the shock body. I had to use the thicker longer cable ties that weigh more, but what else could I do I had already cut it off the flimsy bit of metal ( I did cut off the little tail of excess cable tie with some satisfaction). I know string should weigh less than cable tie but if it gets wet then you would carry additional weight every time it rains and I don't think I could live with that.
I always think as you approach 0 grams you can approach the speed of lite
every ounce counts
Postby NitroDann » Sun Mar 11, 2012 1:32 am
Wun911: Does your car have windows?
bigdog
King of the kennel
Postby bigdog » Sun Mar 11, 2012 9:06 am
Pamex
Postby Pamex » Sun Mar 11, 2012 9:11 am
Wun; Carbon Fibre cable ties? :mrgreen: :twisted:
Postby 93_Clubman » Mon Mar 12, 2012 11:51 am
...& a licence tat. :mrgreen:
Charlie Brown
Postby Charlie Brown » Tue Mar 13, 2012 9:50 am
Almost right. :D The 10AE was the only NB8A that had ABS (2 channel not 4 like the NB8B).
Users browsing this forum: No registered users and 367 guests
