NitroDann's Long Awaited Garage Thread
mrpham
Re: NitroDann's Long Awaited Garage Thread
Postby mrpham » Thu Mar 08, 2012 6:17 pm
Nice work!
Also love the discussion on the log manifolds, it's something I wanted to build my self when I go FI and glad to know that they work well for our application (under 300hp). Was thinking of using the standard SR20 turbos as they come up for sale cheap and often.
With this sort of setup, is it worth getting the manifold ceramic coated?
Current Forum Specials!
Postby NitroDann » Thu Mar 08, 2012 6:31 pm
That IS a used (though GCG rebuilt) SR20 turbo. :mrgreen:
As for ceramic coating, it makes it rustproof, and helps a lot with engine bay heat control. Though I doubt you will get a noticeable performance improvement on this manifold.
When are you looking at doing it Pham?
mrpham
Postby mrpham » Thu Mar 08, 2012 6:47 pm
Not too sure yet, sometime this year though. Also want to get my ITB build on the way soon and have some more track time with that while I slowly collect parts and tools (mainly a welder), too busy these days to rush any thing.
Might have a chance to pick up a cheap BP engine, so not sure what to do about that yet either...
Starting to miss turbo engines :P
Postby NitroDann » Thu Mar 08, 2012 6:58 pm
Cheap BP? Easy as.
As for the welder, either buy a good one like mine, or hire a mig, tack the manifold and have someone who is good weld it up.
Postby NitroDann » Fri Mar 09, 2012 4:21 pm
Quick build update.
Ive decided against using a braided stainless oil feed line.
For a few reasons.
As dweezle found out, getting a universal one and a multitude of fittings sucks. The hose will never be the right length either.
Braided hoses suck, actually, non oem flexible hoses suck. They flop around, end up ziptied everywhere, and braided ones slowly saw your car in half.
This is the reason I use a TIG welded hardpipe for all reroutes, not the regular floppy universal water hose. Its strong, lasts forever, stays put on its own and looks professional.
So heres the oil feed line.
Not as exciting looking as 4 feet of coiled up braid, and anodized fittings everywhere, but this is how Mitsubishi chooses to feed Evos, how Ferrari chose to feed the F50... etc etc. I think you get it. The pipe will be bent into place when its fitted onto the car.
It looks oem, it works oem, it has oem reliability, and supports itself like oem. Win, win, win, win- in my book.
Dweezle
Postby Dweezle » Fri Mar 09, 2012 4:29 pm
I like that!
I assume there would be no issue with flex as the engine and turbo can not move independently??
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Postby NitroDann » Fri Mar 09, 2012 4:51 pm
Correct.
Edit: In the above post I meant F40.
Apu
Postby Apu » Fri Mar 09, 2012 5:17 pm
You're a bitch man! Just like some other guy I know here tempting me with a CF seat...just makes me want to go out and spend money. :evil:
...must...resist!
Sean
Postby Sean » Fri Mar 09, 2012 5:43 pm
Solid pipe is tidy!
gslender
Postby gslender » Sat Mar 10, 2012 8:47 am
How ya doing the return then?
jorgan92
Postby jorgan92 » Sat Mar 10, 2012 9:09 am
Solid work Dan, real credit to you (just read most of your build thread)
Postby NitroDann » Sat Mar 10, 2012 9:10 am
Braided stainless. Theres nothing near the return, and as its a thick vertical hose it doesnt need supporting, SS drains are never an issue.
wozzah1975
Postby wozzah1975 » Sat Mar 10, 2012 9:29 am
Looking good mate :)
Woz
Postby NitroDann » Sun Mar 11, 2012 11:46 am
And some more...
Thoughts, questions?
Still to do..
Fit cat to exhaust, finish dump pipe, air filter..
Thats about it.
Edit: At this rate, someone might actually buy this engine :mrgreen:
rxmx
Vehicle: NA6 - Turbo
Postby rxmx » Sun Mar 11, 2012 1:26 pm
Looks good dan, haw close are you to the firewall where the hard line exits the engine?
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
