NitroDann wrote:Any time you want to give me advice here Warren just do it!
Thanks,
If I had to be fussy I'd say I like my turbo manifolds to collect and be equal length, but I'm sure this unit will be fine for the application
Woz
Thanks,
NitroDann wrote:
So the absolute limit possible on the turbo may drop from say, 300rwhp to 280, due to manifold design. To combat this you need to use a bigger turbo, which comes with all the downsides of a bigger turbo (lag etc).
This setup is designed to replace a supercharger. The car has an ecu, injectors, clutch and intercooler, and made 180rwhp or so.
As for my intake, Ive no idea on dyno figures. Id like to know but dont have the funds.
Thanks for the questions,
NitroDann wrote: Turbos use exhaust gas to spin them, if an sr20 without a turbo makes 150rwhp worth of exhaust gas, and a B6 at 4psi makes the same amount, then in both examples both engines will be spooling the turbo just as hard and making the same airflow rate. its just you have to wait to get to that 4psi on the 1.6L first.
