SE turbo flange?
Vilko
Re: SE turbo flange?
Postby Vilko » Sun Mar 04, 2012 8:51 pm
and1 wrote:I'm pretty sure the SEs don't use a T3 flange. It's an IHI turbo but the flange is different to the Subarus. It's pretty unique in its own way. If you want to keep the manifold try messaging flyin Miata to see if they still do the housing upgrade. Or BNRSupercars
Good suggestion, but I would rather change the manifold and turbo than start modifying a stock turbo.
Interesting about the T3, I might look into skyline stock turbos and their size. A mate should have one lying around.
and1
Postby and1 » Sun Mar 04, 2012 11:37 pm
I didn't realise you were looking for a manifold as well. The OP was about the flange so I assumed you were looking at just a turbo swap.
Anyways the Begi manifold looks rather stock and you can then just mount a 2nd hand S15 turbo or something with a T25 flange.
That's my plan when I have a bit more dosh..
2005 Velocity Red MX-5 SE
Garage thread
Vilko
Postby Vilko » Sun Mar 04, 2012 11:53 pm
and1 wrote:I didn't realise you were looking for a manifold as well. The OP was about the flange so I assumed you were looking at just a turbo swap.
...I am the original poster :D
I would prefer to keep the stock manifold and try and find a turbo to suit. But Im not going to have a turbo not suited to the power, or pay an unreasonable amount of money just for the sake of a manifold.
Postby Okibi » Sun Mar 25, 2012 9:24 pm
Not sure if it helps but here's the details from an SE turbo
VJ350405
24041A
BP8J
