Interesting drip
CoachOz
Interesting drip
Postby CoachOz » Thu Jan 26, 2012 11:06 am
The recent wet weather has given me ample opportunity to test out the weatherproofing on my soft top.
In heavy rain no water leaks whether driving or stationary
In light rain no water leaks above 60 kmh or below 50 kmh or when stationary
In light rain a very slow drip from above the drivers quarter window but only between 50 - 60 kmh
All of my drain channels are clear.
Any thoughts on this?
2020 ND 2 GT
2000 NB Heritage
[imgImageHeritage 2 by Peter Rodgers, on Flickr[/img]
JRBasia
Interesting drip
Postby JRBasia » Fri Jan 27, 2012 12:36 am
Haven't experienced this but could the soft-top rubber seals around that area have worn down(?) enough to let some water through at that specific speed? That's a very strange circumstance to leak.. Goodluck on your fix.
Johnny
Hjt
Re: Interesting drip
Postby Hjt » Fri Jan 27, 2012 12:51 am
I had the drip your speaking off, i fixed it by pulling the rubber back off the window frame and cleaning it, whilst also checking the seal on the soft tops frame. I noticed your from Bonny Hills, i have a co-worker who surfs up there often sounds like a beautiful part of NSW!
Garry
Postby Garry » Wed Feb 01, 2012 9:13 am
Have you checked the little drain at the top of the quarter window? It allows excess water from the windscreen header seals to run into the door seal and out the bottom. Also check your soft top latch adjustment. Another thing to look at is the condition of the soft top. If it has shrunk to much across the width water can get underneath it and past the side window seals.
ishotabear
Postby ishotabear » Wed Feb 01, 2012 1:39 pm
I have the same drip but it's because my soft top doesn't seal itself properly because the guide cap thing has broken off the latch.
This thingy.
CoachOz
Postby CoachOz » Wed Feb 01, 2012 5:43 pm
Update:
Lots and lots of rain today and the MX was parked out in it all day. A few drops on the seats seeming to come from the same place both sides and a bit more as a result of opening the door (not the rain coming in). But once I drove off, no more drips.
I did discover when I got home 25 klms later that I had a wet bum as a bit of water had pooled in the small crease on the leather driver's seat - none on the passenger side
2020 ND 2 GT
2000 NB Heritage
taminga16
Postby taminga16 » Wed Feb 01, 2012 7:10 pm
My NB leaked air and a little water at low speeds and the fix was to check the alignment of the quarter vent and bend the frame gently if required.
Greg.
Postby 93_Clubman » Sat Feb 04, 2012 12:01 pm
CoachOz wrote:A few drops on the seats seeming to come from the same place both sides and a bit more as a result of opening the door (not the rain coming in).
On the NA6 at least getting water dripping on to the seats was as a result of water getting between the rubber at the top of the power window glass & the power window glass itself.
RJ45
Postby RJ45 » Mon Feb 06, 2012 11:53 am
CoachOz wrote:Update:
Fixed this leak on my NB by adjusting soft-top latches.
Adjust til gap between windshield header & convertible top is 3-7mm.
Mine was about 12mm before I adjusted, so this also sorted out a rattle :)
Instructions of this are in the NB8B Workshop Manual:
09 Body & Accessories - EXTERIOR TRIM - 09-16 - Convertible Top Adjustment.
NB8C+PSS9
CoachOz
Postby CoachOz » Mon Feb 06, 2012 6:42 pm
The latch is at max tightness
2020 ND 2 GT
2000 NB Heritage
RJ45
Postby RJ45 » Tue Feb 07, 2012 1:18 pm
CoachOz wrote:The latch is at max tightness
Is the gap between 3-7mm?
Mine was 1.1mm before, now 7mm @ max adjustment.
Not sure what can to do if it stretches more; but I guess either new latches or maybe add some rubber stripping between the windshield header and OEM rubber to make it a tighter fit.
NB8C+PSS9
Postby 93_Clubman » Tue Feb 07, 2012 1:38 pm
Latch adjustment, & if necessary repair, here: http://www.miata.net/garage/garagetops.html
RJ45
Postby RJ45 » Tue Feb 07, 2012 2:19 pm
Eventually I'll need more adjustment, good to know there's another option other than my previous guess.
Thanks man, I hope this also helps the OP :)
NB8C+PSS9
CoachOz
Postby CoachOz » Tue Feb 07, 2012 7:50 pm
Unless I've missed something, the link does not make suggestions for when we run out of adjustment
2020 ND 2 GT
2000 NB Heritage
RJ45
Postby RJ45 » Thu Feb 09, 2012 11:35 am
You're right, it doesn't show how to increase adjustment, Sorry if i confused you.
I shouldn't bother trying to multi-task while on conference calls :)
Also, the rattle hasn't gone away, just less often, but still annoying.
NB8C+PSS9
