Help with sr20de manifold removal to fit startor motor
initial D
Postby initial D » Mon Feb 06, 2012 8:53 am
I am trying to replace the startor motor on my n15 sss. I have taken injectors out some hoses and oil lines, bolts which hold the manifold and it still doesn't want to come off?
Anyone know where i can get a PDF of this or workshop manual would be great
project.r.racing
Re: Help with sr20de manifold removal to fit startor motor
Postby project.r.racing » Mon Feb 06, 2012 8:59 am
put it on stands and access it from underneth. don't do it the hard way.
or just remove the intake piping and battery + tray and hang yourslef over the wheel arch to access it.
initial D
Postby initial D » Mon Feb 06, 2012 9:19 am
Thanks, i have the car on ramps and have taken the intake,battery,oil lines. Do u think there is stuff more bolts and lines i need to disconnet?
project.r.racing
Postby project.r.racing » Mon Feb 06, 2012 11:13 am
the start motor is attached to the bell housing using 2 bolts. you shouldn't even need to remove much. just gotta be double jointed to reach around the lay shaft from underneth.
going from the top, if you up your belly on the strut top and lent over in a dangerous position, then you should be able to access it underneth the throttlebody.
initial D
Postby initial D » Mon Feb 06, 2012 11:28 am
ok man i will try that in the afternoon
