rotary engine swap
london67
rotary engine swap
Postby london67 » Fri Jan 27, 2012 11:14 pm
hi guys...anyone done rotary engine swap??? how expensive....how hard?? any info would be great..... thanks david
toppertee
Re: rotary engine swap
Postby toppertee » Fri Jan 27, 2012 11:25 pm
http://forum.miata.net/vb/showthread.php?t=357075
Click the link bit of info for you
4sfed5
Vehicle: NA6 - Turbo
Postby 4sfed5 » Sat Jan 28, 2012 6:40 pm
a club mechanic has done it..
he frankensteined the gearbox with an rx7 front and mx5 rear housings.
welded a new cross member extension to the original cross memeber to hold the front of the rotary block.
massaged the trans tunnel to clear the bell housing as the rotary sits the crank height higher than a 4 cyl.
thats the main bits. other things like low pressure fuel regulator for the ida carb etc etc.
Jace
Postby Jace » Sat Jan 28, 2012 7:00 pm
If you have to ask...
london67
Postby london67 » Sat Jan 28, 2012 9:49 pm
ok...rotary may not be the answer....l live in brisbane...any suggestions on performance mods??? l have 1990 roadster with 1.6 help............... :oops:
Jace
Postby Jace » Sat Jan 28, 2012 10:36 pm
It's been covered a million times, and what you want specifically relates to your definition of 'performance'.
Have a search and a general look around the forum and you'll find the answers you need.
Help yourself first :)
Postby NitroDann » Sat Jan 28, 2012 11:05 pm
Step 1: Name a car, that goes as fast in a straight line as is satisfying to you.
Step 2: Calculate its power to weight ratio.
Step 3: Calculate the power needed to make your mx5 have the same ratio (mx5s weight and power available on wikipedia) "X".
Step 4: Search
Step 5: If you STILL need help, open an intelligently worded thread asking how to achieve X rwhp.
Postby Okibi » Sun Jan 29, 2012 2:23 am
David,
Go chat to the guys at MX5 Plus, they'll be able to show you different options and explain the costs involved.
Users browsing this forum: No registered users and 60 guests
