Torsen LSD not locking up
rs_simmo
Re: Torsen LSD not locking up
Postby rs_simmo » Tue Jan 24, 2012 7:14 pm
Hellmun wrote:18mm is HUGE for a rear sway bar on an mx5, the 16mm whiteline is already too big for most people coupled with the 24mm front. If it has a normal amount of pre-load an 18mm will cause wheel lift on most round-abouts (my 16mm does setup just no preload) etc due to the camber of the road surface to promote drainage. A torsen will still spin an inside wheel whenever the inside wheel is unloaded, they need a little torque on both wheels for lock-up to occur so even if it was the right diff..that situation may still cause you grief.
rs_simmo wrote:I found the problem- I paid for a torsen diff from mx5 mania and they gave me
An open which had type 1 torsen written on it.
Not happy. - will be taking back
Mad Maz..
Postby NitroDann » Tue Jan 24, 2012 7:46 pm
Hellmun is the fastest n/a mx5 guy in the country, listen to him. I believe i also posted it, if you lift a wheel, the car will open diff, torsen or not. 18mm will lift every time.
rs_simmo
Postby rs_simmo » Thu Jan 26, 2012 1:17 pm
Dweezle wrote:Ahhh good old Mania......
Update: went down to mania, they looked back through the computer and saw that I had purchased a torsen, looked at my diff, found it was an open, apologized and refunded the difference
Very nice people to talk to and very impressed by their customer service!!
Mad Maz..
deviant
Postby deviant » Thu Jan 26, 2012 2:20 pm
So they have now fitted a torsen?
rs_simmo
Postby rs_simmo » Fri Jan 27, 2012 7:11 am
They asked me whether I wanted a torsen or to just refund the difference in price, I took difference, and then sold the diff
Mad Maz..
deviant
Postby deviant » Fri Jan 27, 2012 2:48 pm
Ahhh okay...I was worried that you had taken a partial refund on a diff you never needed in the first place.
Were you not tempted to get them to fit a torsen?
rs_simmo
Postby rs_simmo » Sun Jan 29, 2012 2:31 pm
deviant wrote:Ahhh okay...I was worried that you had taken a partial refund on a diff you never needed in the first place.
Nah the car has been parted out
Mad Maz..
Users browsing this forum: No registered users and 46 guests
