Hi,
As subject say, if ya replacing the rocker cover with a new gasket, do you have to put that liquid gasket goo all over the front and back? I remember reading that this was a required procedure... Hoping someone can confirm if this is the case or not.
G
Rocker cover goo with/without new gasket?
- gslender
- Vehicle: Non MX-5
Re: Rocker cover goo with/without new gasket?
between cover and gasket and under the corners of the camshaft humps. don't forget around the spark plug sections also.
