Dweezle's Malibu Gold.
Dweezle
Re: Dweezle's Malibu Gold.
Postby Dweezle » Tue Jan 17, 2012 6:48 pm
Long story short, I had a potential buyer for the car and turbo kit, so I stopped all work on the installation.
A week later the potential buyer no longer required a sexy Malibu Gold so she's mine again. :lol:
Finally installed the LC1 and gauge today.
I ran the wires down the side, I even used a soldering iron to punch small holes in the little tabs to run the wires neater on the inside.
It ended up a lot neater than this when it was finished.
I went to Quickfit to weld an O2 bung onto the stock exhaust pipe just before the Cat.
This is just until I get the turbo downpipe installed.
Anyways, here it is working with what I think to be correct figures.
Someone far more knowledgeable than me, please speak up and confirm or deny these are accurate readings. :oops:
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Postby NitroDann » Tue Jan 17, 2012 7:21 pm
yeah looks good.
Guessing stock ecu?
Dweezle
Postby Dweezle » Tue Jan 17, 2012 7:37 pm
Yeah stock ecu.
Heading down to garage now to make sure tunerstudios sees the LC1 and pack the car!!
Jeremy Clarkson
Dweezle
Postby Dweezle » Tue Jan 31, 2012 2:57 pm
ALRIGHT!!!!!!!!
Well i have bothered the crap out of quite a few people in the last few weeks.
Huge Props out to
NITRO-DANN, GSLENDER & ZOSSY.
Without your help i would still be the clown crying in the garage.
The Megasquirt is all good now.
(Hint, It is always the simplest thing that is wrong)
I think i almost have everything together now besides a Intercooler/piping for the installation.
Pickled up a VL Commodore V-TPS from a wrecker today for $40.
Really felt ill calling people and asking for a VL part.
I have issues obviously. :mrgreen:
Then when i got there the guy wanted to talk about Commodores.
When i told him it was for a MX5 he quickly lost interest. :roll:
I have the LC1 Installed in the car with the G5 Gauge.
It is now also hooked up to the MS.
I can get the car to start quite easily.
The issue i am having is when it starts it runs at about 1500rpm for a second or 2 then crashes down to about 300rpm then usually it keeps bouncing between the two.
Almost stalling then reving back up to about 1500rpm.
Here is a log if anyone out there could be so kind to take a look and help me out.
http://www.mediafire.com/?0x3b30spy0nxl95
& my MSQ
http://www.mediafire.com/?3n3zn73678x0vat
I am fishing through the MEGAMANUAL trying to figure some things out.
I have ordered a set of RX8 Injectors from 949 RACING, hopefully they will arrive soon and should be plenty for my goals.
Will most likely grab a cheap Intercooler from JUSTJAP.
Looking at this
- Bar & Plate Core
- 550x180x65mm
- 2.25 inch Inlet & Outlet
- 12 Month Warranty
For $159, i believe it should do the job nicely.
Again, if i am way off... Someone please tell me :oops:
I will still be running the standard diff, Yeah it will go bang, hopefully not the same day.
But when it does i will have to get ye ol Torsen involved.
I am booked in tomorrow for a emissions test at Botany RTA.
Was stoked to call today and they could fit me in tomorrow.
I have heard you need to wait a few weeks usually.
So i will whack the stock ECU back in and get a report on the car as standard.
The Engineer i have spoken to has asked i get one before MODS if possible.
Its free here in NSW, So hey, WHY NOT!!
Again, can not thank everyone enough for your time and efforts.
It is a steep leaning curve and i am trying to catch up!
Jeremy Clarkson
Dweezle
Re: Adding a variable TPS to an NA6
Postby Dweezle » Tue Jan 31, 2012 9:18 pm
Oh hell yeah!! Thankyou.
I search for hours for this stuff.
Clearly searching the wrong thing.
I think its just too lean.
Will have a play in the morning!
Jeremy Clarkson
Postby NitroDann » Tue Jan 31, 2012 9:27 pm
Mine is rich, and slightly more advanced bellow all my super light cruise cells and idle.
dann
zossy1
Postby zossy1 » Tue Jan 31, 2012 9:56 pm
NitroDann wrote:Mine is rich, and slightly more advanced bellow all my super light cruise cells and idle.
dann
Ditto - I idle best at around 13.5-13.8 AFR.
Dweezle
Postby Dweezle » Wed Feb 01, 2012 8:50 am
BOOYAH!!!!
Thanks guys.
more fuel did it. :P
Oh ignore the motorbike start half way through.. Not my car!!
Jeremy Clarkson
Dweezle
Postby Dweezle » Sat Feb 11, 2012 10:06 pm
one word.
BOOOOOOSTED!!!!!!!!
It is in.
car makes noises that make you go mmmmMMMMMMM!!!
It all began one faithful morning, Tues the 7th i believe.
After packing the car, (yet again, i did this a few weeks ago only to have Megasquirt issues. Turns out the stock TPS will kill the Megasquirt, THANKS GSLENDER!), i left for Newcastle.
Nitro-Danns to be precise.
Arriving there at about 8am we got straight into it.
Was in such a rush all 17 Hours it took so i did not get really any pics during the build.
Only thing i regret.
A timelapse would have been AWESOME.
Also i was short on a few things, Hose clamps etc etc.
So a few of these had to be scrounged up to get me home.
Rest assured, all rusty hose clamps will be changed
First up was to make sure the MS was working this time.
In it went, car started up, got Connected to a laptop and went for a drive to get a start on the tune.
Straight back into the shed to change over to my brand new 450cc Denso Injectors from 949. (Emilio had them to me in 2 days. CHAMPION!)
Changed the REQ Fuel and straight back onto the quiet back streets.
Dann is a bit of a whiz at this "tune ASAP dealeo".
Within 20 Mins of him furiously mashing keys and me moving the throttle on his every command we had the car pulling harder than i have ever felt.
Seriously, i would have been happy coming home with the car having that extra power up top that it never had before.
It just felt bigger.
Once we were happy it was straight back onto the stands and 'Operation -Remove Boring bits' started.
Was not long before we had the car to this point.
I bought some 2" & 2 1/4" Mild Steel piping as Dann was going to weld up some Intercooler piping for me.
So at this point i continued on with what i could and he started measuring and figuring out the piping path which was complicated by my WANT OF MY AIR CON TO STAY!
Much to Danns disgust :lol:
Clearance was going to be the issue.
He nailed it.
The hot side is all one piece.
Super happy with it.
He apologised for the welds.
OH YEAH, THERE DISGUSTING :roll: :roll:
He then moved on to the Cold side,
This was a little interesting as i had a few bits of Aluminium that i wanted to use with the 2 1/4" Mild steel.
The Aluminium piping had the Idle Bypass and BOV Outlet welded.
Dann welded the AIT sensor bung in.
He again apologised for the dodgy weld.
yeah cos it looks TERRIBLE??? :roll: :lol:
So a few Silicone joiners where used here but it works Great.
I will remove the Hot & Cold side piping shortly and spray it all Black.
The Intercooler, "which Dann had somehow made a bracket and installed it while i must of been daydreaming" looked great.
That too will come out for a quick Black cover to keep it slightly more stealth.
It is a Cooling Pro 550mmx140mmx65mm unit from Just Jap.
Pretty good build quality for $140.
When i remove the piping i will look at raising it slightly if possible but i really wanted the stock radiator to still have flow as i still have Aircon and did not want to be chasing cooling issue at the moment.
Off course once track work begins i will have to re-vist this.
We realised that my stainless oil feed line fitting was not M10x1.5 for the OEM feed from the block.
After running around like mad for a hour Dann had a Lightbulb moment.
Use the Feed from the back of the head.
Low and behold the threads matched. :beer:
The came the oil return to the sump.
We removed the Aircon Compressor and i crossed fingers and prayed to the car gods as Dann drilled away!
Went great.
We ran the old oil through the engine then some spirits to flush any shavings out but honestly nothing seemed to get inside.
Topped up with Penrite Full Synth 10W50. $40 not going to complain.
The came the final installation of the turbo and 'Turbo tony Downpipe'.
HOLY F**K!!!!!!! :evil: :evil:
This was a nightmare.
My patience had died, It just would not fit.
Sad to say, some Hammer work happened here.
The main issue i had was the Aluminium Aircon line, which seems to not be the usual routing, got in the way of the downpipe.
So i had to bend and force the downpipe past it.
It is touching but if it become as issue i will get the aircon re routed.
Also, if i learnt one thing this long day.
It was V-BANDS!!!!
Honestly, if you are building a Turbo system.
Use V-BANDS!! If you do not, i will personally stab you in the face with a screw driver.
Due to the design of the Greddy kit which this sort of loosely is based on, the only way to install the downpipe is to have the manifold loose on the studs, then slide the downpipe into position (hammer is you have a awful air con line in the way) then fumble around to get the 4 studs through then nuts then try and get it all back onto the engine and hope you got it all right.
We did not a few times.
Needless to say once it was completed never want to touch to again.
I had to remove the windscreen reservoir, and am now kicking myself for not going in to the group-buy for a NOPRO unit.
Oh well i am sure i can sort something out.
At this point all that was really needed was to finish hooking up the oil lines and refill the radiator and start her up.
She fired straight up at about 1130pm.
We went for a awesome night drive with Dann again at the keyboard giving me a safe tune.
The first time i heard the turbo start to spool up i got giggly.
Then when i actually felt the boost come on, well i lost it.
Could not stop smiling.
I left Danns place at about 1245am for a 2 hour trip back to Sydney.
I could not get my Pod filter on, so it was a unfiltered trip back but man it sounded good.
Still have a ton to do, but the hard part is done.
On the to do list -
Have to wait for some silicone joiners to arrive so i can finish my intake
Stock exhaust requires replacing obviously
Boost controller
Stock Diff will not last long :oops:
Want to plumb BOV into the system
Rewire the AIT sensor
Mount the MS properly in car
Paint pipes and I/C
Mod the Undertray slightly to fit back on
Mod the Flyin Miata Heatshield, just rubs slightly on the downpipe
Keep reading/learning about tuning.
Hopefully this can all happen in the next week or so.
HUGE thanks to Nitro-Dann, the Dudes got HECTIC-Skillz!!
What would have taken me weeks, he got done in a day.
Even at this rough stage the car is at it is amazing.
I Love it.
Engineering is my goal, the tune will be hardest part. Might have to try and find a tuner who is willing to have a play with a Megasquirt to pass emissions.
It is running quite rich at the moment, (hey it was seriously a 45 minute tune :shock: ) so that can all be sorted in time.
One other issue i have is after a Full Boost blast when i let off the throttle i get a cloud of Blue smoke.
I believe it could be a PCV issue.
I bought a GTX PCV from Repco, but testing with my mouth it seems to only fully seal sometimes. So that may be no good also.
Meh, i am sure i can sort something out.
Jeremy Clarkson
Postby NitroDann » Sat Feb 11, 2012 10:34 pm
The smoke may be either the PCV, or as I suggested the oil feed being too unrestricted. If you remove the PCV hoses from the intake, and just let them hang, you will know if its them. by removing them from the intake system. Hey, the engine has a few K's on it right. :D
Not claiming to be an expert here, but I reckon there will be a 500 odd rpm spool increase when I do the exhaust, and probably another few hundred once you wind some timing into the 2500-3500rpm cells.
Anyone wondering about the slight one slight bend that isnt mandrel in the 5th photo, this is where a 30* silicone elbow is going. If the BOV pipe wasn't aluminium I would have done 1 piece hotside AND coldside piping, but alas mark wanted a joiner at that bend so he could remove the piping without removing the lower radiator hose.
Glad you are happy Mark. :mrgreen:
PS: Mad props to mark for doing almost everything right, including buying a quality steampipe manifold, braided oil lines, a real ecu- and it was installed and set up while the car was bone stock, along with stainless T bolt clamps for everywhere except those last 2 off the turbo, which I scrounged in the shed.
Apu
Postby Apu » Sat Feb 11, 2012 10:39 pm
Niiiiice!
It's making me rethink not turbo charging my car... :twisted:
A.Chen89
Postby A.Chen89 » Sun Feb 12, 2012 12:11 am
wild, dann your garage seems like it's a decent workshop!
Jace
Postby Jace » Sun Feb 12, 2012 12:14 am
fuuuuu this just gave me a massive kick of motivation... at 12.15am of course...
awesome work, now i want the same thing!
Apu
Postby Apu » Sun Feb 12, 2012 5:32 am
Mark, did you do Dann's coolant reroute as well? Might be worth it - I'd assume that would help you squeeze out a few extra ponies as you refine your tune.
I saw one he did...took me a while to find the "stealth" pipe.
