Front Mudguard Liner Mounting Screws/Clips, Door Plugs etc..
Hi All - My car was missing the drivers front plastic Mudguard Liner when I bought it, and I have found a liner, but my Mazda dealer can't help with the steel mounting screws and clips, or the plastic plugs and screws.. Does anyone know of a later model Mazda etc, that uses similar mounting screws, or anywhere I might get something I can use? I also need new plastic plugs and screws for the doors that the armrests screw into, or maybe I'll just have to trawl the wreckers.. Any help appreciated.. Cheers Derek
Re: Front Mudguard Liner Mounting Screws/Clips, Door Plugs e
Supercheap etc. have racks of plastic bags with small quantities of plastic body clips,bolts and other fittings......
Good to take a sample along to compare...
Silver Nomad
2002 NB8C
2002 NB8C
Thanks Sylvia - I'll give them a try. Cheers
- de Bounce
Closest I have found at SCA (that work) are called SCRIVE CLIPS 8MM - HOLE P/No PP68Silvia wrote:Supercheap etc. have racks of plastic bags with small quantities of plastic body clips,bolts and other fittings......
Come in a packet of 2.
Bursons also stock or can order plastic fittings. Insofar as screws are concerned you will need a sample or a proper description of the fastener involved.If you have those screws already on the vehicle then you can remove for an id. A specialist bolt and screw supplier can then point you in the right direction.
- tuned_to_fly
http://www.mx5parts.co.uk/fastner-wheel ... p-883.html
All those parts will be on that site somewhere!
http://parts.arlingtonmazda.com/
Lots of new Mazda parts here. I've used them before, got stuff fast.
- Jim007
You will spend a small fortune buying clips and screws new. If you have a local pick a part go trawling and grab anything you see. I do up a lot of cars and spent 3 hours at Pick A Part one day and came away with about 200 plastic clips of various kinds for bumpers etc at a grand total cost of $5.
When I was young I spent 90% of my money on Fast Cars, Women and Alcohol. I guess I wasted the rest.
- de Bounce
After paying the proverbial fortune at supercrap for a couple of clips, I went looking on ebay
Found a seller "thecarson008" who sells them in bulk packs.
Jim007 wrote:If you have a local pick a part go trawling and grab anything you see. I do up a lot of cars and spent 3 hours at Pick A Part one day and came away with about 200 plastic clips of various kinds for bumpers etc at a grand total cost of $5.
+1 for your local Mazda wrecker, if you have one local that is.
I am guessing but are these what you are looking for?
I need those kinda clips for rear mudguards!!!!
the guard clips and screws, i mean. they seem to be what im missing.
Users browsing this forum: No registered users and 156 guests
