Hi guys,
So I think my alternater is on the blink, here's why I think this
Was returning from the city to gosford on Sunday and while sitting at the lights waiting for a green, my charge light (battery symbol) come on. After driving away from lights charge symbol went out. Checked the battery when I got home13.1V.
Run the car at idle from cold on Monday for 25min nothing. Got 13.8V to 15.1V when fully loaded up with high beams, foggies, a/c etc. No charge symbol come on while running.
Wednesday (tonight) went for a gentle 20min cruise to a matyes and charge symbol comes on, I was getting 11.7V on the multimeter at idle. Turned car off, got 12.8V. Started the car charge symbol stayed on drove down the road, got to 3000rpm and the the symbol went out and not seen again.
Have checked belt as it Was changed last month, seems fine, not loose.probably a little fiirm if anything.
Suggestions ladies and gentlemen???
P.s car contains a moded 98 nb8a engine with lumpy arse cams and an idle between 900-1200rpm
Thanks in advance,
Ben
alternater on the blink??
Re: alternater on the blink??
If it's the alternator, tapping the alternator body when the battery light is on might also make the light go off.
- greenMachine
If it is the NB8A alternator, be aware that it is regulated by the ecu. AFAIK, all other NA/NB have internal (to the alternator) regulators.
If you need to replace it be sure that whoever does the job knows the difference.
not sure about you guys, but im really not a fan of reaching into a running engine bay.
i will be doing the change if it is shot. will be removing the old one and taking all the part numbers off it befor ordering a replacement.
thanks guys
thanks guys
mmx005 wrote:not sure about you guys, but im really not a fan of reaching into a running engine bay.
Broom handle or similar if you have to.
- Russellb
- RIP Nov 2014
Hi Ben
Are you running the NB8A Alternator ???
Or are you using the NA8/6 Alternator ???
Need to Know so I can Help
But From What you describe it sounds like one OR maybe two of the Phases of the Alt have DIED
more than likely the one that excites the magnetic field of the alternator.
Or it could be a blown Fuse/ broken wire to the exciter side of the ALT
Check that then is batery voltage on One of the pins in the 2 pin plug ( i forget which pin )
one pin controls the light the other is to excite the magnetic field
using a test light test between the two pin plug of the ALT and ground
with the IGN on one will glow dim and the ALT light will glow dim
the other will glow BRIGHT and now glow from the ALT light
if this test has these results the the ALT is DEAD
My ClubmanRebuild
MX5 SE Rally car is HERE
i have an NB8A running adaptronic ecu and modded engine
thanks for the heads up, will try your test b4 i rip the alt out.
cheers :-)
cheers :-)
- Russellb
- RIP Nov 2014
mmx005 wrote:i have an NB8A running adaptronic ecu and modded engine
cheers :-)
Forget those test i told you about , they dont work with the NB8A ALT
time for a new or second hand one.
My ClubmanRebuild
- slimx
- Vehicle: NB8B - Turbo
im not too familiar with the issues but look
When i bought my car
myn use to go off and on .. as if something was loose i use to check it all the time.
I checked the battery it was at normal volts this that.. I went to a auto electrician they told me my alternator was out. over charging... blah blah
I got pissed off because i knew nothing was wrong with it. I was ujst soo sure..
I left it
I convinced myself that one day if it blows ill change it its only like $100 anyway.
One day i went to mx5mania.
One of the workers drove my car and asked me if i wanted to fix that light.
My air temperature sensor was replaced. And bang it DISSAPEARED!! forever
Wouldnt hurt to try i paid $15 for myn
I left it
