Steering wheel off centre
CoachOz
Postby CoachOz » Sun Jan 01, 2012 7:42 pm
My steering wheel is a bit off centre when the wheels are straight ahead. This has been the case ever since I bought the car. Do I rectify this with a wheel alignment or by taking the steering wheel off and resetting it?
2020 ND 2 GT
2000 NB Heritage
[imgImageHeritage 2 by Peter Rodgers, on Flickr[/img]
PaulF
Re: Steering wheel off centre
Postby PaulF » Sun Jan 01, 2012 10:37 pm
Unless you've taken the steering wheel off recently, I'd say wheel alignment.
CoachOz
Postby CoachOz » Tue Jan 03, 2012 10:22 pm
I haven't taken the wheel off, but the previous owner might have
2020 ND 2 GT
2000 NB Heritage
Postby NitroDann » Tue Jan 03, 2012 10:41 pm
Id bet one of your REAR wheels is not aligned.
PaulF
Postby PaulF » Tue Jan 03, 2012 10:44 pm
This post is based on general rather than practical knowledge. If anyone sees a flaw in my logic then feel free to point it out.
If the steering wheel is misaligned, then when the wheel is centred it won't be in the centre of the rack. This means that it will be further towards full lock one one side than the other. Pull the wheels to full left lock and take note of the position of the steering wheel, then go to full right lock and look again at the position of the steering wheel. Full right lock should be the exact mirror image of full left lock. If it isn't the exact mirror image, then that would suggest that the steering wheel is not properly aligned. If it is the exact mirror image, then that would suggest that the issue is in the suspension alignment.
Postby NitroDann » Tue Jan 03, 2012 10:50 pm
paul, correct.
PaulF
Postby PaulF » Tue Jan 03, 2012 10:51 pm
:mrgreen: Do I get a gold star?
Postby NitroDann » Tue Jan 03, 2012 11:05 pm
No, you do however get an na6, when you have saved up enough.
cojack
Postby cojack » Wed Jan 04, 2012 10:18 am
Turn your steering wheel lock to lock (from left to right) and note down the position of the when the wheel is full lock. Eg: 10 O'clock or 2 O'Clock. If they are even then the steering wheel was not straight when you had alignment done. Otherwise you could remove the steering wheel and re centre it.
CoachOz
Postby CoachOz » Thu Jan 05, 2012 11:09 am
I tuned the wheel and yes it is off centre when I compare full lock to full lock
2020 ND 2 GT
2000 NB Heritage
PaulF
Postby PaulF » Thu Jan 05, 2012 11:40 am
Sounds like you've got your answer then.
