NA8 vs NB8
- Learner Driver
NA8 vs NB8
Hey all
Am going to convert my NA6 to a BP as soon as i find one available
Are there any major differnces between NA8 and NB8?
Does the NB8 need the NB gearbox etc?
Planning on turboing the BP mid next year, so is one better then the other for forced induction?
Did a bit of searching, but couldn't find an answer
Cheers, Jared
Cheers, Jared
FASTER, FASTER, FASTER. Until the thrill of speed overcomes the fear of death
- Vehicle: Non MX-5
Re: NA8 vs NB8
massive differences. and 2 versions of the NB BP motor. google didn't turn up anything?
Re: NA8 vs NB8
If its street dríven go a 99+ motor and ms3.
Re: NA8 vs NB8
Sorry I should specify, I meant a VVT motor, so 01+.
- Learner Driver
Re: NA8 vs NB8
Google didn't give me anything decent.
What's involved in a VVT conversion from NA6?
Is going to be street dríven, and then a snail put on mid next year.
- geofiz
Re: NA8 vs NB8
NitroDann wrote:Sorry I should specify, I meant a VVT motor, so 01+.
Why VVT overs VICS?
NB8A - mostly stock for now
Re: NA8 vs NB8
Spooling a turbo.
Vics helps increase port velocity at low rpm which helps a little but restricts total flow at high rpm.
VVT give much more volumetric efficiency at lower rpm, and more exhaust port timing spooling a turbo hard and fast.
Also, an NB motor has solid lifters, making cam swaps much better.
And 99+ heads flow much better than 94-97 heads.
- Learner Driver
Re: NA8 vs NB8
Ohk. So how much is involved in a VVT transplant?
cheers
cheers
- bensale
Re: NA8 vs NB8
Lightyear has just done a complete transfer of all the running gear from an nb8b (vvt 1.
into an na6. Saw it yesterday, seemed to fit well !! I like the idea of a Frankenfive
Aren't the vvt engines more difficult to turbo though? I vaguely remember it being a complication for the SP's development.
NA & NB gear boxes, diffs etc are all interchangeable too.
www.othersideproductions.com
Re: NA8 vs NB8
VVTs have 10:1 compression, almost high enough for an E85 turbo engine at 15psi. And they have VVT which a lot of ecu's have trouble effectively controlling.
- bensale
Re: NA8 vs NB8
Makes sense. Cheers for the explanation.
- Learner Driver
Re: NA8 vs NB8
OK so the NB VVT motor is the way to go then. do they bolt up to the NA6 gearbox? or worth doing complete swap (gearbox diff tailshaft etc)?
- Learner Driver
Re: NA8 vs NB8
Also, does that mean custom crossmembers etc?
Re: NA8 vs NB8
Straight bolt in. But the diff wont survive a week and the gearbox will make it 6 months. Do the full swap. Neither of those time frames are exaggerations.
- Learner Driver
Re: NA8 vs NB8
Sweet as
NB VVT engine, gearbox, diff and tailshaft.
Does that then require NB C.Vs and hubs, brakes etc?
Users browsing this forum: Bing [Bot] and 0 guests
