Steering wheel off centre
- CoachOz
My steering wheel is a bit off centre when the wheels are straight ahead. This has been the case ever since I bought the car. Do I rectify this with a wheel alignment or by taking the steering wheel off and resetting it?
- PaulF
Re: Steering wheel off centre
Unless you've taken the steering wheel off recently, I'd say wheel alignment.
- CoachOz
I haven't taken the wheel off, but the previous owner might have
Id bet one of your REAR wheels is not aligned.
- PaulF
This post is based on general rather than practical knowledge. If anyone sees a flaw in my logic then feel free to point it out.
If the steering wheel is misaligned, then when the wheel is centred it won't be in the centre of the rack. This means that it will be further towards full lock one one side than the other. Pull the wheels to full left lock and take note of the position of the steering wheel, then go to full right lock and look again at the position of the steering wheel. Full right lock should be the exact mirror image of full left lock. If it isn't the exact mirror image, then that would suggest that the steering wheel is not properly aligned. If it is the exact mirror image, then that would suggest that the issue is in the suspension alignment.
paul, correct.
- PaulF
No, you do however get an na6, when you have saved up enough.
- Learner Driver
Turn your steering wheel lock to lock (from left to right) and note down the position of the when the wheel is full lock. Eg: 10 O'clock or 2 O'Clock. If they are even then the steering wheel was not straight when you had alignment done. Otherwise you could remove the steering wheel and re centre it.
- CoachOz
I tuned the wheel and yes it is off centre when I compare full lock to full lock
- PaulF
Sounds like you've got your answer then.
Users browsing this forum: Google [Bot] and 9 guests
