Sloooooooooowwww warm up thermostat $40 WTF ?
Basho
Postby Basho » Fri Dec 30, 2011 9:34 pm
My car has decided to take about 20 minutes or 15ks to get close to warm so at a guess I'd think that my thermostat is on the way out so I called good ole Mazda, - $40 for a frigen thermostat, is there any other brand thats worth a pinch at a sensible cost or is it Mazda or eat drood ?
:beer:
JBT
Re: Sloooooooooowwww warm up thermostat $40 WTF ?
Postby JBT » Fri Dec 30, 2011 10:20 pm
A quick search reveals that Tridon http://www.tridon.com.au/partfinder/default.aspx reckon you need a TT240-180 for an NA6 (is that what you have?) and Supercheap http://www.supercheapauto.com.au/online-store/parts-maintenance/cooling/thermostats-caps.aspx?id=4043&brand=Tridon have them for about $17.
Basho
Postby Basho » Sat Dec 31, 2011 6:36 am
:D Thanks for that.
A quick search before I posted also revealed that a member on here had had nothing but trouble with that brand and also that Mania had the OE for $25 but that postage would nearly absorb the cost advantage.
I don't object to to anyone taking a profit I just hate being exploited.
JBT
Postby JBT » Sat Dec 31, 2011 6:51 am
I wouldn't worry about one person's experiences. CPC also make thermostats. Repco have an "up to 50% off" sale until 4 Jan 12. RACQ discounts are also available normally.
project.r.racing
Postby project.r.racing » Sat Dec 31, 2011 8:15 am
Mazda just use Dayco thermostats. I recently brought one online for $22 delivered from this parts supplier. Delivery is slow though.
http://www.eziautoparts.com.au/index.ph ... 1306744612
Basho
Postby Basho » Sat Dec 31, 2011 8:40 am
project.r.racing wrote:Mazda just use Dayco thermostats. I recently brought one online for $22 delivered from this parts supplier. Delivery is slow though.
Hi , Thanks for that, you wouldn't know the part No by any chance ?? :D
project.r.racing
Postby project.r.racing » Sat Dec 31, 2011 11:00 am
BP engines are DT27, and you just select the letter for opening temps.
I think B6 engines are DT15, again A or B or C for opening temps. Not 100% sure on the B6 thermostat part number though.
Do the B6s use a giggle pin like BPs/323s?
Gasket is the same for B6/BP, DTG15 from memory.
It cost me $19.75 for the thermostat, gasket and shipping. I also brought the 82C opener, instead of the 88C opener for my 323, since it gets tracktime.
Basho
Postby Basho » Sat Dec 31, 2011 12:45 pm
Thanks mate, Repco sale on so only $16.89, job done and done.
The OE thermostat was siezed open didn't need the boiling water to figure this one out.
Dayco Part No is DT27A-BP.
It's a 52mm with 82c oppening. it has a jiggle pin and is offset,
The OE gasket is stainless steel with what looks like a black sealant though it could have been a coating it also plays a part in keeping the thermostat seated.
I have cleaned and reused this with a thin layer of silicon sealing on each side , I'm going to be refilling the coolant tomorrow when this has mainly cold cured.
Two things to note:
One/ The OE aperture is 30mm and the Dayco one is 27mm so I will be keeping a close eye on the temp gauge.
Two/ The construction of the OE one I removed was about twice as sturdy as the Dayco replacement.
Postby Mr Morlock » Sat Dec 31, 2011 3:29 pm
hardly worth getting into a lather about- save it for the whales. Where do you buy thermostats- automotive parts suppliers - either specialists or generalists like Bursons. If you buy based on price the process is flawed- a cheap thermostat is not going to use "quality" materials nor a quality system that is actually followed. Dayco is likely to be an ok product. Mazda may well source OEM supplied product and it should be good. I can buy from multiple sources close to home and have the product is not more 30mins. Whats the value of time?
Basho
Postby Basho » Sat Dec 31, 2011 3:47 pm
The origional question was reasonable product, reasonable price ? the rest is incidental, so who's lathering ?
project.r.racing
Postby project.r.racing » Sat Dec 31, 2011 4:03 pm
Mr Murlock - drives around for 30 minutes and pay $40.
Basho - drives less to parts shop and pay $20.
Both - receive same product. lol Whom is getting better value? Including their own time?
Users browsing this forum: Bing [Bot] and 5 guests
