anyone using project mu brake pads?
hamx5ter
Re: anyone using project mu brake pads?
Postby hamx5ter » Sat Dec 24, 2011 5:56 pm
I've used A1RMs all around before and they were great balance of road and track pad. they also bit from cold and were easy in the rotors. not too dusty.
I switched the fronts to Project Mu Club Racer pads when I swapped the front brakes over to NB8B rotors and calipers and also did s/s lines at the same time.
its a bit hard to tell just which bit contributed to the current brake setup, but the brakes are miles apart from before.
I just had the most awesome trackdays ay Wakefield yesterday, did probably 80 laps and brakes were spot in all the way through... sure the pedal is a little softer, but I am only running dot4 so a bleed is in order (I will be making a call shortly :P) but the pads just fabulous.
they seem a lot more dusty than the A1RMs though..
Jace
Postby Jace » Mon Dec 26, 2011 12:07 am
My wheels are textured mag finish so i need the bitey-est dust free pads i can get.
hamx5ter
Postby hamx5ter » Mon Dec 26, 2011 1:33 am
The A1RMs have plenty of bite and not too much dust at all.
Postby NitroDann » Mon Dec 26, 2011 11:03 am
As far as Im aware, all proper race pads are dusty as hell. Its just the compromise you have to make.
Postby Lokiel » Thu Jan 12, 2012 9:56 am
Here's some interesting/useful info I've just read at http://clubroadster.net/vb_forum/showthread.php?t=55555 that may influence your thougts on pads:
"The Carbotech SM package includes:
Full vehicle set of rotors (Front and Rear OEM brake rotors approved by Carbotech for use with their pads)
Front Carbotech XP10 Front Brake Pads and Carbotech XP8 Rear Brake Pads
This package is set up for a track only road racing Miata, such as a Spec Miata. The XP10/XP8 combo has been proven to be the best brake choice for most people racing Miatas, the XP8 is a slightly less aggressive compound and is used on the rear to bias the braking, as bias is not adjustable manually. Spec Miata's benefit from a lighter rear brake to avoid rear lock-up under extreme trailbraking conditions and rain racing.
For your car, I would suggest either the Carbotech 1521 compound or the AX6 compound on all corners. The 1521 is Carbotech's street/auto-x compound and the AX6 is a more aggressive auto-x compound that can be used on the street with the side effects of a little more dust and low temp squealing. We use the 1521 on our street Miata and it is a very nice pad that will outlast your vehicle, and is extremely easy on rotors.
If you want a bit more bite, I would step up to the AX6 unless you are overly concerned about dust and noise (although not nearly as much as the comparable Hawk HP-Plus pads, which are harsh on rotors and put off tons of dust). These pads would be ideal for auto-x and will work great for weekend driving.
The Carbotech rotors that come with the package are not cheapies, but an affordable OEM replacement, however they have proven themselves on our Spec Miata's and many others to be known good racing rotors and worth the extra couple of bucks. I would be wary of extreme cheapies, we've used $20 rotors from NAPA before and took them off after one session because they felt like they were covered with oil (yes, we did wash the oily residue off before we used them!).
As for the other choices out there, they might be cheaper, but from what I've noticed the difference has been in the rotor wear. When we used Hawk products, we tore through rotors so fast, at least 2 or more sets a season, about every other brake pad change. With the Carbotech pads, we can make it a whole season (at least 10 weekends a year) or more on one set of Carbotech rotors, which made up for the difference in price of the pads over options like Hawk. The choice is yours of course, but that's why we use Carbotechs (plus they are awesome for not locking up tires under trail braking, which is important in SM).
I can get some other options for you as well if you're interested. We have Hawks and can get Axis too. I will put together kits like the SM kit for these pads in the future."
Jace
Postby Jace » Fri Jan 13, 2012 8:18 pm
I just went with EBC greenstuff and RDA slotted rotors. Next up is new hoses and a MCS to get the feel right.
Postby Lokiel » Fri Jan 13, 2012 9:35 pm
Jace wrote:I just went with EBC greenstuff and RDA slotted rotors. Next up is new hoses and a MCS to get the feel right.
For a normally aspirated NA/NB, MX5 Parts UK recommend EBC GreenStuff for DD (possibly because they're manufactured in the UK) so you can't really go wrong with them Jace.
Jace
Postby Jace » Fri Jan 13, 2012 9:51 pm
I didn't realize they were made there until I spotted a poster at the brake & clutch shop. Much more reassuring than them being made in Uzbekistan or somewhere ridiculous.
I had them on my last car (but didn't change fluid then due to being a noob) so knew they were pretty good. Much better with new rotors and fluid now!
Users browsing this forum: No registered users and 206 guests
