Got the passenger side engine mount bracket done today.
And made a start on the drivers side bracket
Then I took a few pics of the man cave where I've been making all the parts for the swap.
Looks like a Tig??? But isnt...?
That oil filter issue has come up with all the other "Kliata" swaps I have seen on the interwebz. Seems like an easy fix with a remote filter mounting kit...?
Looks good so far. What intake are you going to use? Custom? I seem to recall one of the others using modified GSXR1100 TB's on a custom mani...?
Beelzeboss wrote:I'd love to go ITB's but I can't see how they'd fit under the stock bonnet. At the moment I'm planning on making a custom manifold using the stock intake flanges cut down to about 30mm high and welding on my own intake runners and plenum. The throttle body is a very weird shape because the original manifold had that Mazda VICS system so I might use a throttle from another car.
The oil filter fix isn't too difficult as you point out, I think I'll make my own relocation setup
I think I could live with a small bonnet mod for ITBs ;)
