shaking at 130km/h
im_boostn
shaking at 130km/h
Postby im_boostn » Mon Dec 19, 2011 9:38 am
hey guys,
car seems to have developed a rear end shaking, not sure if it's road or not but this was on the freeway. It didn't felt normal and car has been making rattling/loose stuff noise lately.
I will need to bring it to someone that knows for a check up.
Any recommendation around the western suburbs of Melbourne?
Don't mind spending a bit to get it done once and done properly.
cheers.
Phil
Re: shaking at 130km/h
Postby hks_kansei » Mon Dec 19, 2011 9:50 am
First step before taking it to any workshop.
Go to a tyre shop and get a wheel balance.
It's not expensive, and it's the most likely cause for vibrations at speed.
If that doesn't help, then it's maybe time to look at the more expensive possibilities.
im_boostn
Postby im_boostn » Mon Dec 19, 2011 10:07 am
yep, thanks for the advice.
Will be getting 4 new tyres and alignment done before bringing it to the shop
NMX516
Postby NMX516 » Mon Dec 19, 2011 11:57 pm
These cars are quite sensitive to unbalanced wheels and tyres - the earlier the model MX5, the more sensitive. Vibration at speed can be a common complaint, but is most often related to wheel balance. All it can take is a small hit to a wheel or a flat spot on a tyre, and you're done for! It can take much frigging around to sort, requiring patient balancing by a tyre tech who is willing to try and solve the problem. It can be almost impossible with used tyres if they have worn unevenly.
im_boostn
Postby im_boostn » Tue Dec 20, 2011 12:25 am
The tyres are quite old, and lately cars been doing single wheel skids as soon as I jump off the clutch a bit, I reckon you guys are onto something.
NMX516
Postby NMX516 » Tue Dec 20, 2011 9:03 am
It depends on the wheels too. Cheap blingy rubbish made in the back streets of Bangkok won't do.
Users browsing this forum: No registered users and 238 guests
