- orx626
- Vehicle: NC - Rotary
Re: Renesis NC Track Car - In the Build
Hope that this is the first of many records for the R35. The car is still untouched since WTAC 2011 in August.
- 16bit
wow, thats pretty damn fast!!
i just figured out why the car looks so funny from the side. its on 18's and the road car is on 20's.
- orx626
16bit wrote:i just figured out why the car looks so funny from the side. its on 18's and the road car is on 20's.
Yeah, DOT approved semi-slicks are somewhat limited in R20's! It will interesting to see what the tyre manufacturers do in the coming years.
- orx626
The experience and knowledge gained through the R35 project to date has definitely affected the path I was going down with the NC. What began as a project to build a road racer has really transformed into a project to build a "time attack" weapon. I see so much more opportunity to improve the performance...mind you 6 years has now passed...and when I think about it, I really don't think it was going to end any other way....not that I'm anywhere near finished!!!
Originally I was going with the genuine Mazdaspeed body kit..you know, the front bar, rear bar and side skirts. But that's probably a bit too good for a race car and probably not as aero dynamically effective as I was now wanting. So the Mazdaspeed body kit is now on my road registered NC and getting the necessary colour change. I'll post some piccies once finished. Fibreglass/carbon fibre components are better to suited to the application. I've made decisions on the front and rear bars and acquired the below items...they are a bit of a blank canvas as they will be appropriately modified for better aerodynamics.
The rear bar is a fibre glass Mazdaspeed copy.....
The front bar is from Odula and is also fibreglass.....
Another major decision has been to go back to the original wheel/tyre combination (well the rear at least) which will require the installation of extended wheel arches and the cutting of steel work to suit. This was really the catalyst for the change in direction...a plasma cutter will be involved!
The wheel/tyre specs are as follows:
Front: Enkei RPF1 in 18 x 9.5 - 45P offset fitted with Toyo R888 in 255/35 R18
Rear: Enkei RPF1 in 18 x 10.5 - 15P offset fitted with Toyo R888 in 285/35 R18
I sourced the CF wheel arch extensions from Moss Motors (I can't remember who the manufacturer is) and have only stuck them on to get a feel for the work that will be required to get them installed and the work necessary to allow the required wheel travel. Now its looking pretty mean!
Hopefully the Xmas/New Year break will bring some real progress.
Merry Xmas and Happy New Year to all!
There's far too much dust on those cars
- orx626
Jace wrote:There's far too much dust on those cars
You're welcome to come and wash them all Jace!
orx626 wrote:Jace wrote:There's far too much dust on those cars
Will do, then I'll drive them dry for you too.
Beautiful work mate, the front bar reminds me of the mighty ducks.
- 16bit
nice fd.
glad aero has become a part of this build on the same level as the engineering.
hopefully this could be fastest rwd car!!
- lightyear
- Infinity & Beyond
- Vehicle: NA6 - Turbo
Will be good to have an nc time attack car. I would cut the rear lower half of the flares off like the new wrc cars. Better aero...
- timk
Some very nice fabrication there, always look forward to updates in this thread
http://www.facebook.com/purefabcustom
EFR6758 run-in tune 259hp atw on 10psi pump 98 dyno dynamics
E85 tune - 445hp @ wheels 17psi
Im just about to do this exact same thing and have searched the net and your the only person i can find thats done it.
In the early pictures it looks like you put in an mx5 front subframe but when the engine is in it looks like you are using the rx8 front subframe.
is this right ? ive looked at both the mx5 and rx8 front subframes and they look like they will fit.
can you confirm this please
- zero00
Looking good as always!! Saw it again yesterday when I picked up my NB - thanks to the guys for their excellent work as usual Didn't get a chance to ask you were you heading for QR this Monday? [do understand how busy you are!!]
Roger D-SUNSHINE COAST
Are you competing in WTAC 2012 with the R35?
