Miata roadster grill good?
Steampunk
Re: Miata roadster grill good?
Postby Steampunk » Fri Dec 16, 2011 9:37 pm
Firstly, a soft toad will cause less damage than a hard rock.
Secondly, the AC condenser resides before the radiator.
sailaholic
Postby sailaholic » Fri Dec 16, 2011 9:52 pm
You're supposed to hit them with the tire not the rad!
Postby Lokiel » Fri Dec 16, 2011 10:11 pm
sailaholic wrote:You're supposed to hit them with the tire not the rad!
That's the real reason I wanted 225/45/15 tyres - more "Squishing Power" :twisted:
Just beware that grilles, no matter how well designed, impact negatively on air flow which is not a good thing - on an SE, you need all the cooling you can get.
I originally installed a Lockwood mesh grille to protect my Cooling Pro intercooler but had to remove it when I fitted my Ryokurob tow hooks and didn't want to cut up the grille. If my intercooler gets beat up, I'll just buy a new one, they're not that expensive.
Silvia
Postby Silvia » Sat Dec 17, 2011 10:57 am
Two parallel threads here ; suggest it continues in the "General Chat" forum only.
Silver Nomad
2002 NB8C
