OVERHEATING PROBLEM
oko0ol
OVERHEATING PROBLEM
Postby oko0ol » Fri Dec 09, 2011 5:51 pm
Hi guys can somebody out there can help me solve my problem.my na6 was overheating so i changed a new water pump,timing belt kit,thermostat and flushed the raidaitor and changed the fan and took for a drive today and it was still overheating.help me solve this problem thank you..
aviper4u
Re: OVERHEATING PROBLEM
Postby aviper4u » Fri Dec 09, 2011 8:14 pm
all i can suggest is confirm temp gauge is accurate? check heat sensors? and also inspect for signs of bad head gasket, bubbles in radiator, or streaks in oil?
good luck
plohl
Postby plohl » Mon Dec 12, 2011 8:42 am
Check the line between the overflow tank and the radiator to make sure it isnt blocked.
plohl
Matty
Postby Matty » Mon Dec 12, 2011 10:27 am
From being in the same boat several years ago: buy a new radiator.
Postby Regie » Mon Dec 12, 2011 5:22 pm
air in the system possibly
Postby Hammer » Mon Dec 12, 2011 10:23 pm
Is the fan actually turning when the temp gets hot?
I recently just replaced the motor of my radiator fan as the plug got loose and it will intermittently lose connection and stop the fan. Wiggling it usually fixes the problem but only temporarily as the plug gets loose again on the next bumpy road.
So I got it replaced and it fixed the problem.
Users browsing this forum: No registered users and 123 guests
