NB Bumper
Re: NB Bumper
Postby Regie » Wed Dec 07, 2011 2:13 pm
there is a screw that sits vertical in the front of the wheel well.
pull the inner guard back at the front and you should see where it goes
Re: NB Bumper
Postby sliq » Thu Dec 08, 2011 1:28 pm
apart from that screw regie talks of, there's also a grey plastic clip that attaches the front bar to the chassis. it's located directly below the headlight. mine was busted until i had it replaced. it wriggled out a few cm's now and then when it was broken.
Re: NB Bumper
Postby Regie » Thu Dec 08, 2011 8:55 pm
BarryB wrote:Thanks Sliq. Have had one go at it this morning and found a loose screw just behind the inner guard. Have tightened it up and all is well at this stage.
BarryB
sweet...too easy
and yeah i forgot about the clip that Mike suggested..could be the next step if the screw resecure fails
