Gear changes a bit crunchy.....
Basho
Re: Gear changes a bit crunchy.....
Postby Basho » Sat Dec 03, 2011 10:37 pm
93_Clubman wrote:
93_Clubman wrote:
Basho wrote:Heavier ?--any particular recomendations ?
There was a noticeably heavier/ weighted NA6 gearknob in the same style as the original NA6 one.
Remembered I had one in the cupboard - just checked & identical to the OEM NA6 gearknob, except that it's weighted & weighs 200 grams - don't know what the standard NA6 one weighs as my NA8 has the standard NA8 one which is different to the NA6.
If you want to retain the standard look, AllMaz at Clayton Vic had one mid last year, although MX5Plus should also be able to assist & are closer to you: http://www.allmaz.com.au/
Thanks for that , nick 3 has skunks for sale weighing in at 440grams but at $90 bucks a pop , whilst not wishing to appear cheeeeep, leave me a little orf, even if they're the ducks nuts.
Now I know what I'm looking for fleebay may be my friend :lol:
By the time I get to next Thursday fixings on this this little number will have cost me $2800.00 in three weeks--its starting to sting a tad :cry: snif snif :lol:
Basho
Postby Basho » Wed Dec 07, 2011 8:19 am
Well the end of this saga for me , clutch was done yesterday and after 20 years the poor ole clutch was retired , still had plenty on it but it had wear marks on a one third area side , as though it had not been set square with the mating surface , I didn't notice whether it was the flywheel or pressure plate side dammit , academic anyway I suppose.
My gears now change fine.
I'm going to drop some MT90 in next week and then they will be 'super fine' :lol:
And a 3 ton gear knob :twisted:
Thanks to everyone for thier help and suggestions. :beer:
Silvia
Postby Silvia » Wed Dec 07, 2011 9:17 am
Basho san, Is there a reason you choose MT90 over MTL?
Both seem to have their proponents....
Silver Nomad
2002 NB8C
Basho
Postby Basho » Wed Dec 07, 2011 11:15 am
Silvia wrote:Basho san, Is there a reason you choose MT90 over MTL?
Honorable Silvia, I'm going to use MT90 as it is a hotter weather grade 75W/90 (I live in Surfers) and the gearbox has 80000klms on it , if I lived in Melbourne I would probably use MTL which is an 70W/80-85 given the same gearbox.
Here is a link to a cheapy oil site where many questions answers can be found.
http://www.performancelub.com/Redline%20pricelist.htm
Postby 93_Clubman » Wed Dec 07, 2011 12:40 pm
Even Redline US & Australia have provided differing advice ref MT90 or MTL:
http://www.mx5cartalk.com/forum/viewtop ... 5&start=15
Indeed, in the following Redline discriminate between MT90 or MTL in 5 or 6 speed MX5 GB:
viewtopic.php?f=29&t=31206&p=443760&hilit=speeds#p443760
So, given you're in QLD Aust (so hotter climate) & you feel your MX5 NB8C (so 6 speed GB) gear changes could be better, it's probably a fairly fine line between MTL & MT90 for you. But give the MTL a go, as the only downside seems to be manga's comment that it sounded a bit thin in his NA8 5 speed GB.
Basho
Postby Basho » Wed Dec 07, 2011 5:51 pm
93_Clubman wrote:Even Redline US & Australia have provided differing advice ref MT90 or MTL:
In order to be sure I was on the right track I contacted Harold at performancelube and here is his response-
" I'd more incline to go Redline MTL, or superlight shockproof. Price are
all the same at $25/qrt. You need 2+l so 3 qrts."
Oh and mine is a 1992 NA6 5 speed , I'm going to call him tomorrow as I want to ask about Amsoil MTG 75-90.
I'm a bit buggy about the 75W90 as thats whats specified for the temp range here.
Silvia
Postby Silvia » Wed Dec 07, 2011 6:05 pm
I understand that 2 quart bottles are sufficient and just over the required amount...
Silver Nomad
2002 NB8C
Basho
Postby Basho » Wed Dec 07, 2011 9:26 pm
Silvia wrote:I understand that 2 quart bottles are sufficient and just over the required amount...
I changed my gearbox a couple of weeks ago (5speed) and wih a side jack on I squashed in 1.8 litres exactly .
Silvia
Postby Silvia » Wed Dec 07, 2011 10:19 pm
Pssst.......buy in store only.. extreme motorsports 197 toombul rd northgate 4013 07 36304377 $22 quart
I suspect different models have differing GB capacities, but none holds more than 2 litres,(I think) so why 3 quarts was suggested is mysterious.....unless the diff. was included - doesn't the diff. take a quart?
Silver Nomad
2002 NB8C
Basho
Postby Basho » Thu Dec 08, 2011 6:30 am
Diff 0.6 litre GL5 80/90 I use this, http://www.tds.castrol.com.au/pdf/6029_LSX.pdf changed mine 3 weeks ago.
Harold sells oil and gives 'free' advice- ah hem :lol:
Silvia
Postby Silvia » Thu Dec 08, 2011 8:29 am
So why DID Harold recommend the 3 quarts of GB oil? :roll:
Silver Nomad
2002 NB8C
JBT
Postby JBT » Thu Dec 08, 2011 8:51 am
Doesn't the owners' manual give the capacities :?:
Postby hks_kansei » Thu Dec 08, 2011 8:56 am
JBT wrote:Doesn't the owners' manual give the capacities :?:
Yeah, but that involves black magic, like reading.
:P
JBT
Postby JBT » Thu Dec 08, 2011 9:05 am
deanb90
Postby deanb90 » Thu Dec 08, 2011 12:35 pm
Just bought 3 Quartz of MT90, was thinking MTL but it's coming into summer. The NC takes 2.1 which is a pain in the ass.
