Have a weird oil leak after putting my new engine in, replaced rear main seal, valve cover gasket, resealed sump using new rubber half moons, CAS o-ring, etc...
It has developed an oil leak at the back of the engine, removed the engine and did a thorough inspection. Valve cover, CAS, sump and rear main seal are clean and not leaking a thing. The flywheel is dry as well as the inside of bell housing.
It is 100% engine oil and not transmission oil.
I've taken a photo and made some markings to explain, the red areas are dry and oil free. The blue areas are where oil was found.
The plate between the engine and bell housing also had oil all around the edges but nothing in the centre.
