Question on pipe for nb8b back of engine to exhaust
lightyear
Infinity & Beyond
Vehicle: NA6 - Turbo
Postby lightyear » Tue Nov 29, 2011 1:24 pm
Hi, i bought a set of extractors for an na8, and the pipe that goes along the back of the motor in the pic doesn't line up or in anyway able to screw together. Is it needed, or can i just block off the holes at both ends??
16bit
Vehicle: NB8A - Supercharged
Re: Question on pipe for nb8b back of engine to exhaust
Postby 16bit » Tue Nov 29, 2011 1:42 pm
pretty sure thats the EGR and can be blocked off.
rascal
Postby rascal » Tue Nov 29, 2011 1:45 pm
No, not needed and yes you can block off both ends.
EGR tube doesn't do much when you're WOT on track..
Thats how mine is now and has been for last 6 mths..
Postby NitroDann » Tue Nov 29, 2011 1:46 pm
Thats the egr pipe. block it.
Edit: damn beaten!
zossy1
Postby zossy1 » Tue Nov 29, 2011 2:00 pm
Rather than block it, do yourself a favour and remove the EGR pipe from the intake manifold, and make a nice little plate to replace it. Much cleaner.
FYI this will trigger a CEL if your car has one. Not really a problem on the track... ;)
lightyear
Infinity & Beyond
Postby lightyear » Tue Nov 29, 2011 2:04 pm
Thanks guys. I will make a plate for the manifold side. The threaded hole for the extractors is huge, about 20mm. So i might just weld the hole inside, it's only about 5mm. Unless i can find a big screw in plug.
zossy1
Postby zossy1 » Tue Nov 29, 2011 2:50 pm
Hmm, that would probably be a gas-thread bung you are after.
Take the extractors down to Pirtek, they will fix you up.
Users browsing this forum: No registered users and 40 guests
