Clutch Problems - NA 1993 - [Pedal] Travel
Greg Roberts
Postby Greg Roberts » Sun Feb 13, 2011 12:52 pm
Hi
The engage / disengage point for my clutch has been getting lower and lower. Then all out of the blue, when cold it is very hard to engage 1st or R and the clutch is biting. Once the car gets warmed up, the bite point gets higher. When engaged i am getting no slippage or sudder. Clutch was done 65k ago by previous owner.
So still can't work out if a hydraulics or clutch plate+ issue. Have workshop manual which talks about 170 - 180 mm for brake and clutch from carpet in rest position. Both around 150mm.
Underneath the clutch fork (before it goes into the bell housing) moves about 11 to 11.5mm (via the slave clutch cyclinder between full travel and no travel.
>> Is 11mm about right for the clutch movement ?
>> Does it sound like a clutch or hydraulics issue ?
Garage quoting about $900 for an installed new clutch .
Thanks !!
rossint
Re: Clutch Problems - NA 1993 - [Pedal] Travel
Postby rossint » Sun Feb 13, 2011 1:48 pm
Is the slave cylinder leaking? if you pull back the rubber boot and see fluid it's leaking. Have you tried bleeding the clutch?
Postby 93_Clubman » Sun Feb 13, 2011 2:46 pm
rossint wrote:Is the slave cylinder leaking? if you pull back the rubber boot and see fluid it's leaking. Have you tried bleeding the clutch?
+1 clutch hydraulics first as the slave cylinders are a consumable.
zossy1
Postby zossy1 » Sun Feb 13, 2011 3:31 pm
+2
Classic slave cylinder symptoms.
Greg Roberts
Postby Greg Roberts » Sat Nov 26, 2011 12:04 pm
Very late post
I had the master and slave master cyclinder replaces and "hey presto" good as new!
Disengage point half way.
I could have done the slave and see then rebook, but i did both so can't say which one was at fault. My guess would be the master cyclinder because the slave was not leaking.
Users browsing this forum: No registered users and 119 guests
