If no help I'll try the Red Line oil, but at $42.50 litre
I get reverse ok and 2nd gets a bit better with warming up.
I'm thinking The Red Line oil may be the equivalent of 75/95w synthetic with Nulon added ....
Silvia wrote:I think I'll go with the Nulon additive first and add to existing oil - quick and cheap.
Silvia wrote:...I'll try the Red Line oil, but at $42.50 litre...
Check before adding an additive to a fully synthetic oil.Silvia wrote:I'm thinking The Red Line oil may be the equivalent of 75/95w synthetic with Nulon added.
Aussie Stig wrote:As Dann mentioned this is the same gearbox used in the S15. It is also used by Lexus and in the RX-7.
There must be a definitive answer out there, these have been manufactured by the hundreds of thousands, for cars much more powerful than the mx5.![]()
Silvia wrote:Well the Red line light shockproof seems to be GL 5 , yet so many people here and in other forums speak highly of the effect on their GB's and none negatively. Is this what you used? I can order through ebay at half retail - thanks 93 clubman - down to $20 quart from one place and $60 total for 2 inc. post from another...hope to pick up at this one and save freight.....
http://www.ebay.com.au/itm/RED-LINE-LIG ... 2a08ee8bda.
Basho wrote:I've got the same issue and had a thought , it's actualy about the owners damn manual which coyly and carefully dosen't specify either GL4--OR--5 , hypoid/mineral , and I know that when I inadvertatly stuffed 4 litres of GL5 into my unsuspecting R34GT-t I may as well have put in quickset , it took 2 gear oil changes before I got half way back to normal.
93_Clubman wrote:Basho wrote:I've got the same issue and had a thought , it's actualy about the owners damn manual which coyly and carefully dosen't specify either GL4--OR--5 , hypoid/mineral , and I know that when I inadvertatly stuffed 4 litres of GL5 into my unsuspecting R34GT-t I may as well have put in quickset , it took 2 gear oil changes before I got half way back to normal.
Basho, I did a search when you asked about this in an earlier thread, but there was very little on this forum, & nothing really concrete, no pun intended! Just searched on GL4 & GL5.
Basho wrote:I'll demand free new gearbox'is for everyone !![]()
Silvia wrote:Appreciate your input with this Basho. Personally I can't believe that Mazda designed a car to be perfection in it's field and allows it to suffer such a fundamental problem.Can't be doing it's reputation much good![]()
Re. the GL5 theory - as I said, many seem to have used the Redline GL5 product with favourable results and little or no criticism, so perhaps there's more to it than it seems.
For example Redline say their product is equal to other grades within it's specification.I think I've even seen it described as GL 4/GL5
But I'm sure Lexus , if it has the same type box,would never put up with any crunching issues in a prestige car, so you are right in searching for reasons...
