Camshafts for early NB8
project.r.racing
Postby project.r.racing » Wed Nov 16, 2011 10:26 pm
So it turns out I have solids and not HLAs in my motor. So my HLA friendly Maruha cams have become paperweights. lol
So what is available for NB8 w/o VVT in a NB8?
Re: Camshafts for early NB8
Postby NitroDann » Wed Nov 16, 2011 10:33 pm
Call around? Also you maruha cams will work fine, they just wont be as good as solid cams in the same specs.
project.r.racing
Postby project.r.racing » Wed Nov 16, 2011 10:46 pm
original base circle 36mm and 36mm, Maruha base circle is 33.6mm and 34.2. ins't that too much for solids?
Postby NitroDann » Wed Nov 16, 2011 11:02 pm
Doubt it. Call around for some shims. Perhaps you will be recommended not to run shims that large, im not sure.
Postby manga_blue » Wed Nov 16, 2011 11:29 pm
So you have Maruha cams for an NA8? If they're F-Cams (= Tomei Poncams) then inlets should have 25292 engraved on them, exhausts 25695.
Resale value on them is pretty good. They cost almost a grand to get them landed here new from Maruha. Why not sell them and buy the right ones for your car?
Postby NitroDann » Wed Nov 16, 2011 11:33 pm
manga_blue wrote: Maruha F-Cams = Tomei Poncams
Interdasting..?
Also agree regarding cams. Pm me if you would like a recomendation for a cam grinder. :)
project.r.racing
Postby project.r.racing » Thu Nov 17, 2011 7:40 am
manga_blue wrote:So you have Maruha cams for an NA8? If they're F-Cams (= Tomei Poncams) then inlets should have 25292 engraved on them, exhausts 25695.
Yes I have the F-Cams, I purchased them directly from Maruha 3 months ago. They are still in there boxes and never been used. Also purchased the cam gears at the same time. Still new in box also.
And yes I will be selling them to purchase the correct cams, hence the point of this thread. But I have only found Toda cams for non VVT NB8 engines. But at $600 per cam, was gonna find/look at other options.
wozzah1975
Postby wozzah1975 » Thu Nov 17, 2011 8:16 am
I do cam kits for the 1.8. I should be able to arrange something for you for about $460 a pair. Depending on the specs on the ones you have now I may be able to work something out for you.
PM me if you're interested,
Woz
Postby manga_blue » Thu Nov 17, 2011 3:30 pm
Also Tomei/Maruha do Poncams/F-Cams and Procams for the NB8A. Same price as the NA8 cams except they advise you must swap to shim-under lifters to use them. That adds a lot of $$$ if you choose to use their lifters.
http://www.maruhamotors.co.jp/miata/par ... ornb8.html
http://www.tomei-p.co.jp/_2003web-catal ... _rset.html
Remember their NB8C is our NB8A.
project.r.racing
Postby project.r.racing » Fri Nov 18, 2011 11:27 am
I am a total noob when it comes to SUBs.
If I get cams where the base circle is 3mm smaller than the OEM cams, do I just purchase replace top discs that are 1.5mm thicker than the originals?
Yes I know I will need to check the passage between disc and cam and measure with 0.05mm. Cause it could be 1.55mm or 1.45mm difference.
But it just seems too easy to measure, order, replace. Am I missing something?
bootz
Postby bootz » Fri Nov 18, 2011 1:51 pm
NitroDann wrote:Interdasting..?
You now making up new words big fella?
If I had an early NB I think I would be trying the Ex-Intake mod for fun and it's pretty cheap.
Postby hks_kansei » Fri Nov 18, 2011 1:53 pm
I seem to recall that it's not really of any benefit for Aussie/Japanese cars.
Something about the car's for the US market had different (softer) cam profiles, so they see a benefit, where with AUDM cars it's no real change.
bootz
Postby bootz » Fri Nov 18, 2011 2:03 pm
Thanks, all the info I had was from the States.
Postby NitroDann » Fri Nov 18, 2011 2:08 pm
Interdasting is a word stolen from a demotivational picture featuring a teenager with down syndrome, who is in a very professor like pose pondering something.
Yeah exintake is a US thing. In Oz our cars start hardcore (:mrgreen:)
Postby hks_kansei » Fri Nov 18, 2011 2:09 pm
Don;t quote me on that, I just remember something about it only really applying to them.
