The carbon fibre time attack/superlap MX5 NB twins blog
mr2 spyder
Re: The carbon fibre time attack/superlap MX5 NB twins blog
Postby mr2 spyder » Wed Nov 09, 2011 8:56 pm
NOICE!
lightyear
Infinity & Beyond
Vehicle: NA6 - Turbo
Postby lightyear » Fri Nov 11, 2011 10:29 pm
Both door outers are done now. But i need to cut out the door handle hole on the left door as i decided after that i was going to use a door handle look, rather than a real door handle. They have just been washed. I will get a better pic once they are assembled.
Postby Okibi » Sun Nov 13, 2011 12:11 am
:mrgreen: I'd love a pair of those!
I think I have a carbon fibre fetish! :lol:
Kikuchi
Postby Kikuchi » Sun Nov 13, 2011 12:54 am
Okibi wrote::mrgreen: I'd love a pair of those!
+1 for both sentences.
they look awesome
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Sun Nov 13, 2011 8:45 am
man those things must be light!!
lightyear
Infinity & Beyond
Postby lightyear » Sun Nov 13, 2011 8:19 pm
Well they are not that light. The whole body from front to back, and top to bottom - basically everything you see in c.f. will weigh about 20kg's. Still, a client of my wife races an old merc, and his bonnet is 40kg's. So he was amazed that the whole body on my car is half the weight of one of his panels.
BadBong
Postby BadBong » Mon Nov 14, 2011 9:00 am
20kg for all panels = not light???...
What are you comparing that to? Air...? :lol:
Kikuchi
Postby Kikuchi » Mon Nov 14, 2011 6:56 pm
Helium filled panels.....
Postby NitroDann » Mon Nov 14, 2011 7:20 pm
Except helium filled panels would be heavier than non helium filled panels....
Imari
Postby Imari » Mon Nov 14, 2011 8:04 pm
Vacuum filled panels. :mrgreen:
Apu
Postby Apu » Mon Nov 14, 2011 8:29 pm
Hmmm...vacuum...filled?
16bit
Postby 16bit » Mon Nov 14, 2011 8:36 pm
unless those panels were first filled with air, in which case the helium filled panels would be lighter.
Postby NitroDann » Mon Nov 14, 2011 8:45 pm
Should just make em out of carbon hey?
Jace
Postby Jace » Mon Nov 14, 2011 9:41 pm
So saucy, and I don't even like the look of CF.
Any reason you're keeping the quarter window's at the front of either door? I assume you're going lexan/plexiglass anyway so why not one larger fixed window?
Are you going to make up a 'fastback' fixed roof with smaller (and lighter!) window seals etc.?
As always, awesome work. I'm watching. 8)
lightyear
Infinity & Beyond
Postby lightyear » Tue Nov 15, 2011 8:04 am
I kept the 1/4 windows so it will act as a frame to hold the window. Last time i made an alloy tube frame - worked fine. There will be a fastback roof. But not straight away. I will just make a normal hardtop, with the only difference being a c.f rear window.
Users browsing this forum: No registered users and 23 guests
