I've been looking at what tyre I'll need to fit to my NC to get close to the same rpm/speed as std for cruising if I install a 4.1 diff for trackwork.
Found this easy to use program which although in MPH is good enough.
http://pw1.netcom.com/~sgalaba/mph.htm
Looks like a 235/45/17 is close and would give a limo ride
Gear speed calculator
Rob
Re: Gear speed calculator
Looks good - tks!
If you've not seen it, useful from a slightly different perspective, especially for multiple comparisons: http://www.1010tires.com/tiresizecalculator.asp
- Russellb
- RIP Nov 2014
Heres the one I use http://locost7.info/gearcalc.php
i like it because you can see your RPM in every gear
My ClubmanRebuild
MX5 SE Rally car is HERE
Users browsing this forum: No registered users and 107 guests
