The carbon fibre time attack/superlap MX5 NB twins blog
- Vehicle: ND - 2
Re: The carbon fibre time attack/superlap MX5 NB twins blog
Damn that sucks, any photos of the damage?
- lightyear
- Infinity & Beyond
- Vehicle: NA6 - Turbo
I went out on the first session of the morning at sandown. On the outlap a guy came off and hit the wall pretty bad and did some damage to his back. So the first flying lap of mine was only to the back straight. So after about half an hour of waiting we got the green light to go again. I went out and on the first flying lap over the hill the car got a bit loose in the rear even tho i wasn't going flat out. I thought nothing of it and it came back, then all of a sudden the rear just went back out again and wasn't going to stop this time. So i had op lock on as it was going off to the infield. Managed to turn the car back facing the right kind of direction and then realised ther was no way of stoping a car on wet grass doing about 160km/h. It jumped over the bitumen driveway that i was hoping would help me slow down. And hit a tyre wall that luckily wasn't an anchored structure. the tyre wall is pretty big and i pushed it about 10m form it's spot. I have full data and video of the incident, and when i see brendan next i will get him to overlay it before i put it up on youtube. Doubt i will ever run fast on a first lap ever again, because it was exactly the same thing that happened to my turbo car. So don't go too fast till you get some heat in your tyres.
Before;
After;
On i brighter note i did get a little done on the racecar.
Before;
After;
Gentlemen we can rebuild IT.
I should have sent you down the vented section from my mould . I think it blends in better than your one it curves more but yours should still work fine.
Sad news and a dramatic photo Dave, hope you're not too shaken up.
- 16bit
I am happy you are fine. Hopefully you can concentrate on the race car now!
- Guran
- Vehicle: ND - 1.5
Ouch! Glad to hear you're ok Dave. There is remarkably little damage considering the speed you were doing. Those tyre barriers are a blessing!
- Vehicle: 10AE - Turbo
that passenger light still looks like it could be usable....
MX5 13B - NFS Racing
PRO-MX5 PB 7.46 @ 179mph & 1.07 60ft
Damn I need a drivers side!
Okibi wrote:Damn I need a drivers side!
Thats ok, I need a passenger
- dave2221
I call bullshit on your crash.....
YOU JUST NEEDED AN EXCUSE TO REPLACE ALL THE PANELS WITH CARBON!!!!!!
- Hellmun
- Vehicle: NB8B - Turbo
Sorry to see, I remember the same thing happening last year to Jason Wright in his crazy WRX at Eastern Creek. That carbon roof doesn't look like it's fitting square anymore, so has the A-pillar moved back or are one of the rear mount points squeezing it? Hopefully the rails are still in good shape but even then people have cut and welded new front ends on. E.g Boyracers old green machine was an NB front end put on a NA shell. So I hope it's still usable as a car when you get time for it.
- Vehicle: ND - 2
Damn, that looks nasty =[ As long as you're ok mate.
sh*t happens, just gotta get back up and replace all the nb parts in cf as well =]
- lightyear
- Infinity & Beyond
Finally started making the doors. I will try and make the other one tonight. Then do the inside halves.
I think it needs a new shell. I might hold onto it and transfer everything - (inside and driveline) to an NA6 when i get the time.
- lightyear
- Infinity & Beyond
Both door outers are done now. But i need to cut out the door handle hole on the left door as i decided after that i was going to use a door handle look, rather than a real door handle. They have just been washed. I will get a better pic once they are assembled.
