How did you find the kit? Did everything bolt up as expected? What was the build quality like?
i started from the turbo outlet i then added the following. the original mazda rubber turbo elbow which is then mated to the begi crinkle finish tube.
here it is attached to the turbo outlet with spring clamps. to the right hand side you will see the outlet/inlet to the intercooler....thats next
this elow attaches to the outlet
closer look at some type of gasket. be careful not to loose or damage this.
screwed in position via 2 torx screws
better look at what's been done
this is the begi steel elbow. it is positioned in the rubber joiner under the wheel well.
this photo shows it coming out from the wheel well
rubber joiner connecting both parts discribed earlier. this just shows the parth to the intercooler
air filter and begi housing
housing partly in position
better look at intercooler pipes
sliding the air filter into position
air flow meter attached
intercooler piping push through
housing lined up to bolt down the power steering system
intercooler pipes clamped
washerr bottle braxket in
washer bottle in
top bar bolted down, 4 screws - 2 per side
air flow meter connected
air temp sensor connected
manual boost control connected
begi throttle body inlet. direct hook-up
final results
washer bottle in
final results
okibi
i bought the very first kit to australia. after a few emails and photos to stephanie at begi she thought it would fit fine.
it's a tight fit alright at the front where the air-con pipes are. apart from that everything was fine and the fittings and build quality ..........perfect.
performance wise not as good as the aem. boys in blue wise. i think you'll get past them as a factory fitted item.
mines got a bit dine to it now but with this i think it looks almost standard
- Bizi
R.e.s.p.e.c.t. on this install. So many pieces to undo, so the first time must have been a bugger! Looks really good from the perspective of a well-engineered, legal intake.
right again. lucky i took a few large meg photos or it's a bin of parts. just waiting now for more stuff to arrive so i can get it back on the road again
did some-one ask for stripes
- Bizi
side ones / bought from the usa -special order
- Aussie Stig
- Stig
Damn that looks nice!
To all the rest, see somebody else also thinks the bastards can defect you for a pod filter, for christ's sake what is the world coming to?
yep, the local mechanic knocked back the rego inspection with the pod on
mx5 plus front plate holder arrived today - no more hole screwing
rear dis ready for painting
paint on
completed
youngest daughter readu for tonights halloween party
paint on
completed
leather hand brake and gearbox boot
console in
seats in
console in
seats in
- Old Dude
Cars looking good BB, your daughter lookslike she should be in the movie "Avatar"
Dale
Dale
MX 5 2001 Grace Green
NB8B
NB8B
the eldest one wondered why she wasn't included with her sister
- Old Dude
Thats easy, she wasn't painted Blue
and after all this is a thread about painting things
cheers
Dale
cheers
Dale
NB8B
NB8B
side stripes.........one side on
