Coolant re route ??
- Vehicle: NA6 - Turbo
Coolant re route ??
I need to do a re route
I looked at heaps of posts and it looks to me like I can just swap the front and back thermo around and then rearrange some new hoses etc
Sounds simple
IS IT ?
Sounds simple
IS IT ?
Re: Coolant re route ??
Yep.
do you have a heater?
Does your ecu turn the fans on?
Yes to both
Its slightly fiddly retaining the heater.
Essentially, you remove the front thermostat hoising and neck etc. And replace with a welsh plug.
Run a hose around the back of the head.
Take the front thermostat housing, remove the sensor, and cut off its boss and block the hole, weld to it a small fitting to feed the heater core.
If you lose the heater you dont have to weld this barb on.
Put the front thermostat houring at the back of the head, with a thermostat in it.
You are done.
You are done.
thanks mate I'll have a look tomorow
na6.
Am I missing something
why go to all the trouble of finding spacer blocks etc is it for looks or what
why can't I just reverse the thurmo housings around and buy some length of hoses
It looks like the sensor on the back would hit on the firewall so why can't I just plug the hole and buy one of those adaptors from super cheap that goes inline
The heater hose can run around the front
I'll have a look at supercheap for a hose that might be the right shape
Everything you just said is right. The block is for the heater core feed.
This is why I mentioned welding one to the housing.
You mentioned the water temo sensor adaptor from supercheap, you dont need one, as your ecu turns the fans on, and that adaptor is only for people who need that front sensor to turn the fan on.
Looks like neither sensor will fit back in the housings
the back one hits the firewall and the front one hits the plastic cam belt cover
I think I need the one from the back as i think the temp gauge reads it
where does the ecu get its coolant temp signal from
olboy
olboy
This DIY coolant reroute on an NB8A might help:
viewtopic.php?f=76&t=40239
The green rear sensor - see pic just over half way down this page:
http://www.miata.net/garage/CoolingSystemProblems.html
olboy wrote:where does the ecu get its coolant temp signal from
There are 3 temp sensors.
The front one,
This is a thermoswitch, it is used to turn on the fans. If you have an ecu that controls the fans you can forget this completely.
The green larger rear one,
This is the temperature sendor for the ecu, it controls fueling and cold starts.
The small rear one, this is for the guage.
The small rear guage one is mounted on the head itself, however when you remove the rear housing to fit the front thermostat housing, you will remove the ecu temp sensor, this is why you need to either weld a fitting to the thermostat housing, or use the fitting from supercheap you mentioned.
Does that help?
The front one,
Does that help?
Coolant re route ??
Sorry to dig up old thread, but am likely to do (or get done) an engine swap in the next month in my NA8, gonna do oil filter relocation at same time, just wondering is it worth doing a coolant reroute? Are they really that necessary? For street use and the occasional 'spirited' drive?
- Matty
Coolant re route ??
Sqeet
- alexpav
I was about to do it on my NA8 also....But didnt like the fact that the head had to come off to get to the thrmo if I ever needed to...
Same as you...its a street car that gets given a squirt every now and again...
Anyways not going to do it myself for that reason...
WILDCARD BITCHESSSS
