billybunter
Postby billybunter » Thu Oct 20, 2011 6:15 pm
track dog splitter
held om by 15 screws
attached to bottom of front bar
billet grille
wheel masked-cleaned and primed
top and clear coated
front bar on
photo of the billet grille
side shot with the white wheels :D
initial D
Postby initial D » Thu Oct 20, 2011 6:21 pm
jizzed everywhere on my keyboard
taminga16
Postby taminga16 » Thu Oct 20, 2011 6:57 pm
Looks the goods BB, thanks for taking us all on the trip.
Greg.
P.S. At the risk of sounding like an A******E is the grille a bit limp to the left? Kick me now. :)
billybunter
Postby billybunter » Thu Oct 20, 2011 7:03 pm
taminga16
you were right -the grille was off alignment. a quick tune and it's now back on track :beer:
Bizi
Postby Bizi » Thu Oct 20, 2011 7:15 pm
Looking like it's white on twack, BB.
The headlights/grille make for a different look to other NB8Bs.
What's the story with the headlights? Is it a CF-style paint job in the headlights?
billybunter
Postby billybunter » Thu Oct 20, 2011 7:20 pm
no - there the original se's headlights - this is standard with the turbo model
Gmi
Postby Gmi » Thu Oct 20, 2011 11:25 pm
Looks fantastic :D .. always loved that white!
billybunter
Postby billybunter » Fri Oct 21, 2011 4:54 pm
todays work area - front left corner
all disc calipers require a tidy up. left front first.
can of 3m caliper paint. clean whole area with grease/wax remover then mask up
then apply 3 to 5 coats
multi-spoke wheel re-painted. first off thorough wipe over with grease/wax remover. .......and i do mean thorough if you want the paint to stay on. followed on a hit with 320 wet dry sandpaper - then clean the whole area again and mask off. prime the surface/both sides. allow a couple of hours to dry then apply top and clear coats
allow a couple of hours to dry and its back on the car
side view
headlight covers.
rub the surface with 320 wet/dry paper. wipe with grease/wax remover then apply the plastic primer
give it an hour to dry then apply top coats
couple of hours later ready to fit to the car. note all the double sided tape contact point. not much room for error here.
on the car
Postby Lokiel » Fri Oct 21, 2011 5:19 pm
Did you try those headlight covers in black? IMHO, there's too much white and I'd prefer to get rid of the altogether - just my $0.02 worth and food for thought.
kris
Postby kris » Fri Oct 21, 2011 7:21 pm
I can't believe this guy posted in your garage thread bro....... massive negative rep if you ask me.
Gmi
Postby Gmi » Fri Oct 21, 2011 7:39 pm
kris wrote:I can't believe this guy posted in your garage thread bro....... massive negative rep if you ask me.
I agree.. Half the brands I've never heard of.
Postby Okibi » Fri Oct 21, 2011 7:54 pm
Sorry about the spam, user deleted. :roll:
initial D
Postby initial D » Fri Oct 21, 2011 9:54 pm
Not bad, but i think the red cailper paint to many people have it.
That's why i painted mine black look's heap's good not ricer at all.
Anyways each is there own.
billybunter
Postby billybunter » Sat Oct 22, 2011 7:42 pm
a few months ago i bought the very first begi cai. i've had it on the car a couple of times. the aem shown performs much better but looks cheap.
the begi is definately a factory look type system and more expensive to buy. remember i have nothing against the aem - as i have both systems and neither are for sale.
reason for the swap. rego due shortly and the aem won't pass this guy. i'll see what happens with this factory look-alike and see how it goes on the day.
if not it's back to the standard system for me.
the pulldown
part 1,
the aem set-up
airfilter off then remove the steel guard
like so
undo these bolts -2 per side
remove the water bottle
should be down to this
remove all tubes and loosen the clamp which attaches to the turbo housing and then pull the lot out
like so
this pipes next
once you un-clamp the top section of pipes remove the left hand wheel from the car. remove the plastic liner and this is what your after
closer look -top clamp only
multi grips work best, clamp on and from the top -give it a good pull :lol:
once out you have this
last part of the job. torx screwdriver required her
photo of the lot
time taken ..........3 days :o about 40 minutes
next time fitting the begi cai
billybunter
Postby billybunter » Sun Oct 23, 2011 5:58 pm
begi cai from this
to this
