NC headlight - replace just the lens??
reflex
Postby reflex » Tue Sep 27, 2011 2:08 pm
I have a damaged lens on my headlight. Lamps etc not damaged, so i'd like to avoid replacing the whole assembly and just do the lens.
Does anyone know if the headlight is a sealed unit or if I can get a lens only?
formerly NC PRHT - currently SH Forester XT
taminga16
Re: NC headlight - replace just the lens??
Postby taminga16 » Tue Sep 27, 2011 5:16 pm
Hi Aaron,
MX5 Plus are wrecking NC's ATM, it may be worth sending them an e-mail.
Greg.
reflex
Postby reflex » Wed Sep 28, 2011 10:09 am
taminga16 wrote:Hi Aaron,
Greg.
Will do! Thanks Greg!
Postby bruce » Wed Sep 28, 2011 2:28 pm
Panelbeaters get broken lights repaired, but I do not know where.
Postby Mr Morlock » Wed Sep 28, 2011 2:59 pm
yes they do get them repaired. There was a place called the Headlamp factory and it was around the Mulgrave area if memory serves. A panel beater probably knows who is renovating headlamps.
reflex
Postby reflex » Mon Oct 17, 2011 10:47 am
I've spoken to MX5plus about a replacement unit and they only have the HID versions available so no good for me, so i'm now looking at other options.
The headlight has been damaged by some douche (me) accidentally wiping it over with a rag that had Acetone on it instead of turps, whoops...DOOH! for those that didn't know, DO NOT WIPE PERSPEX WITH ACETONE! DONT DO IT.....EVER!
Anyway, so in speaking to various people, a recurring theme has been the idea of using ultra fine grit wet and dry sandpaper on the damaged lens, to "cut back" the damaged layers, then polish them up to clear again. I've got the meguiars 'plastix' polish which i've used on the headlights in the past and they come up great. But unfortunately the acetone effectively melts the perspex and its gone all rough and cloudy.
So my question is, has anyone ever tried this, or does anyone have any thoughts?
Thanks.
Postby Mr Morlock » Mon Oct 17, 2011 5:04 pm
there was a recent very good post about the Philips kit which is readily available. Not sure if it will work for your lense. There are no layers on the lenses- these are injection moulded so it is a thickness ( whatever it is ) of polycarbonate and a hard coating. I think it would be worth trying to repair it as there is nothing really to lose. A 2nd hand unit might then be fall back position.
reflex
Postby reflex » Tue Oct 18, 2011 9:50 am
Mr Morlock wrote:There are no layers on the lenses- these are injection moulded so it is a thickness ( whatever it is ) of polycarbonate and a hard coating.
yeah I wasn't sure how to describe it, so to clarify, yes the acetone effectively ate into the lens.
Mr Morlock wrote:I think it would be worth trying to repair it as there is nothing really to lose. A 2nd hand unit might then be fall back position.
I agree, the only potential issue is that I have not had any luck sourcing a 2nd hand unit!
Users browsing this forum: No registered users and 233 guests
