Rx7 control arms into mx5 ?
wazman
Postby wazman » Fri Oct 14, 2011 3:35 pm
Hi all,
I have been searching a little for adjustable lower control arms. This is because at the low height i run the car the factory adjustment is already max and i still have to much camber.......
yes yes i know just raise it and it will handle better too....... but i cant stand being as high as a porsche !
anyway there are heaps of options for the mazda FD rx7 and there standard arms are alloy....... they look similar..... dose anyone know if they fit in any model mx5 ?
ilovedrift.com
wazman
Re: Rx7 control arms into mx5 ?
Postby wazman » Sun Oct 16, 2011 10:46 am
I found some more arm's made by a company in Japan........ http://homepage2.nifty.com/manatee/roadster/piroarm.htm
I dont think they will give roll center adjustment though.
ilovedrift.com
rascal
Postby rascal » Sun Oct 16, 2011 11:24 am
Why dont you just put in offset bushes?
You can put them in top and bottom, and that will give you about 3 - 4 degrees more adjustability.
Obviously put them in the reverse of what the guys do who use them for extra neg camber...
wazman
Postby wazman » Mon Oct 17, 2011 5:59 pm
OK thats a cheap option..... but not great when i wanna make quick adjustments at the track. I do 8 wheel alighnments a year.... because i hit stuff and bump my setting a bit....
What can be done to help with roll center adjustment on the mx5 ?
ilovedrift.com
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Tue Oct 18, 2011 9:13 am
i would give mania a call and ask if they know of anything.
if not email someone like emillio from 949racing or check on the big forum.
zossy1
Postby zossy1 » Tue Oct 18, 2011 9:25 am
Unless you buy the FM arms (which are uber expensive but bloody awesome), you are pretty much limited to offset bushes as your only good option.
Forget the cheap eBay control arms - they are very poor. There is a recent thread on this topic and in there I posted a link to a CR.net thread showing how quickly they go "snap".
Postby NitroDann » Tue Oct 18, 2011 9:38 am
Ive been strongly considering building some upper arms with a threaded for the rod front and rear, it would make getting the perfect setup pretty easy.
It would be sort of hard to modify the stock ones so Ive still to make up my mind how to go about it.
Postby manga_blue » Tue Oct 18, 2011 1:42 pm
Seriously Waz, have you thought about doing some cutting and welding on the subframes to move down the lower control arm mounts? Then you could lower the roll centre while still using standard control arms. It would mean that you could use standard adjusting bolts and straight bushes, rather than the offset bushes which are a PITA sometimes for adjusting and also more prone to losing it.
wazman
Postby wazman » Mon Oct 24, 2011 5:14 pm
I look at the rear cradle...... not much can be done there without a massive engineering job.... :roll:
YAY for google ! :beer:
keep original geometry and drop your center of gravity 35mm ! Woooooo drop spindles!
clicky below !
http://sp-tec.com/shop/14_31.html
ilovedrift.com
charlie_91
Postby charlie_91 » Tue Oct 25, 2011 7:37 pm
wazman wrote:I look at the rear cradle...... not much can be done there without a massive engineering job.... :roll:
clicky below !
holy sh*t :O
16bit
Postby 16bit » Thu Oct 27, 2011 11:57 am
