Erratic Temp Gauge NC
Hey guys,
Yesterday and today i noticed my nc temperature gauge has been very unstable. Normally it sits mid way and doesn't move no matter what. It now sits around 70% from MAX and has at times been only 2-3 bars shy of max temperature.
I have noticed that it climbs when going up hills and drops marginally going down hills!
When idling it occasionally climbs to 80%. Also, after turning the car engine off, a fan seems to remain on for awhile as though its trying to cool the car down- I can't remember this ever happening before.
I don't believe the air intake is blocked, nothing else seems to be a problem.
Any advice?
Any advice?
Kris's NC
viewtopic.php?f=57&t=43276
- JBT
Re: Erratic Temp Gauge NC
This thread may be helpful: http://mx5cartalk.com/forum/viewtopic.php?f=79&t=49246
Hmm thanks for the link JBT...... oh boy........
Kris's NC
looks like a very useful diy. It seems the gauge is doing its job ie alert of overheating. I would be heading to a suitable repairer asap.
Might sound silly Kris, but have you checked the coolant level?
Rob
No I haven't checked the coolant level! Thanks Sailor I will do this ASAP.
Yes, i was looking through that guide.... I don't think my driveway mechanic ability is quite up to that level!
I will have to warn the mechanic prior, would they be likely to have the part available if necessary? I will call MX5 Mania, its also time for a service so i will try and get that done at the same time too.
Kris's NC
- Charlie Brown
Kris,
I doubt that Mania will have a thermostat, they will need to get it from Mazda, cost is around $124.
It's cheaper to get one from Brian Goodwin but pay for fast mail. Don't use US Postal because it will take 5 weeks!!!
Check your fluid level first though.
Oh Kris ):!! Good luck with it man.
- Charlie Brown
Kris,
Something I left out last night.
Your problem is the reverse to mine. Mine ran cold.
First check the fluid level then if that's OK, this is the check for your thermostat.
Run the engine until it's hot, turn it off and then feel the bottom radiator hose. If it's very hot, (ie boiling water in the hose) as opposed to warm to hot, then the thermostat is working because the coolant is flowing through the radiator. If it's not too hot then your thermostat isn't opening properly.
This is where you'll need to go to feel the hose.
You guys are all champions!
I followed the instructions, my coolant levels were near perfect, but a short gentle drive today back from work and my temp gauge was normal for awhile before going through the roof! I was able to nurse the car to the mechanic (i was in that area just in case) and literally pulled up at the right time.
Popping the hood, the coolant was fiercely bubbling, some had escaped through the cap and made a mess while the whole engine looked generally very angry.... after cooling down, then running some diagnostics with the mechanic (like checking for leaks and pressure loss), it was clear that the thermostat had died. I was even able to inspect the hoses as charlie mentioned, and the temperatures of the particular hoses was clearly out of whack.
So I'm not just topless for the weekend but carless, while I wait for the part to arrive and be installed on Monday. Just shy of 60000km and the thermostat dying is a bit concerning- should i be worried? Charlie, did your original last twice as long?
Kris's NC
- monte5
- Vehicle: ND - 2
Interesting mine died at around 70k's (running cold) and then about 2 weeks later CB's died. Possible weak point?
Life's not a dress rehearsal
Glad it's getting sorted Kris, fingered crossed your careful attention to the temp gauge means is hasn't cooked the engine.
- Charlie Brown
kris wrote: Just shy of 60000km and the thermostat dying is a bit concerning- should i be worried? Charlie, did your original last twice as long?
monte5 wrote:Interesting mine died at around 70k's (running cold) and then about 2 weeks later CB's died. Possible weak point?
There doesn't seem to be any relationship to the number of kilometres travelled. They just seems to decide to go when they want too.
I'd say my next major part change will be the clutch. It's done 127,000 klm of daily driving with just a few
One notable NC racer was surprised way back at 80,000 klms that I was still using the original clutch.
Just shows you that if you match the revs on gear changes wear is reduced.
All seems well, new thermostat installed. Temp gauge back to being still as a rock.
BTW, I think if you are not a 'switched on driver' you would infact miss the quite subtle temp gauge changes- there was no warning lights or beeping!
Engine is just as brilliant- no harm done
Kris's NC
