Wet leg syndrome
CoachOz
Wet leg syndrome
Postby CoachOz » Tue Oct 11, 2011 12:31 pm
Got caught in some heavy rain the other day and ended up with a wet right leg.
I've cleaned out the drains in the rubber channel that runs down the windscreen and also in the rain rails at the rear. The seals look fine. Does anyone have further suggestions?
2020 ND 2 GT
2000 NB Heritage
[imgImageHeritage 2 by Peter Rodgers, on Flickr[/img]
Re: Wet leg syndrome
Postby 93_Clubman » Tue Oct 11, 2011 1:11 pm
Upper or lower right leg? Did you happen to notice at the time roughly which direction it might have been coming from?
See dB's post in following for general drain info:
viewtopic.php?f=18&t=49004
CoachOz
Postby CoachOz » Tue Oct 11, 2011 1:43 pm
The drips were coming down almost directly above the door latch - so that's the upper leg. It seemed to be worse when the car was standing still, but that's also when the rain was heaviest.
2020 ND 2 GT
2000 NB Heritage
Postby 93_Clubman » Tue Oct 11, 2011 2:29 pm
If rain's heavy enough or if in a car wash, water can sometimes get between the rubber seal & the top edge of the side window glass. Apart from that, may be the rubber strip between the outside of the side window glass & the top edge of the metal door skin has perished & is letting rain in when it's really heavy & you're stationary.
dave2221
Postby dave2221 » Tue Oct 11, 2011 2:43 pm
IS YOUR SOFT TOP LATCHING CORRECTLY?
MAYBE YOU NEED TO TIGHTEN THE LATCHES?
UGH SORRY FOR CAPS
CoachOz
Postby CoachOz » Tue Oct 11, 2011 6:21 pm
They seem ok, but how do I know the correct tension?
2020 ND 2 GT
2000 NB Heritage
dave2221
Postby dave2221 » Wed Oct 12, 2011 10:58 am
by how firm it is to do the latch up.
just fiddle with it until it feels firm, without beign to hard
Postby manga_blue » Wed Oct 12, 2011 12:28 pm
Postby 93_Clubman » Wed Oct 12, 2011 4:45 pm
Latches might also need adjusting to ensure they are creating the required tension in the soft-top to get a good seal along the top of the windscreen surround & top of side windows:
http://www.miata.net/garage/garagetops.html
Latch repair might even be needed:
http://www.miata.net/garage/top_latch/index.html
Users browsing this forum: No registered users and 253 guests
