billybunter
Postby billybunter » Tue Oct 04, 2011 6:02 pm
front bar coated in plastic primer
bottom part of front bar
under side of bar plastic filled and sanded
first of 3 top coats
top coat on
top and clear coated
job done
billybunter
Postby billybunter » Tue Oct 04, 2011 6:07 pm
just thought i'd mention. just in case you think that there might be a paint run in the centre of the bar from left to right...........definately no run just high reflection from the clear coat
billybunter
Postby billybunter » Wed Oct 05, 2011 6:17 pm
billybunter
Postby billybunter » Wed Oct 05, 2011 6:18 pm
- Vehicle: NC - V8
Postby Regie » Wed Oct 05, 2011 7:52 pm
damn....hot as
cant wait to see this thing finished!
- Vehicle: NC - V8
Postby Regie » Wed Oct 05, 2011 8:17 pm
Borked wrote:You know Regie, You've one sitting in your driveway that you could do a similar project to ;)
easier just to buy a white one
billybunter
Postby billybunter » Thu Oct 06, 2011 5:38 pm
ak_perth
Postby ak_perth » Thu Oct 06, 2011 6:44 pm
Wow, i love the clear repeaters. They always look brilliant on a white car
Apu
Postby Apu » Thu Oct 06, 2011 8:00 pm
Please don't expose all of the car for now...the partly covered tease is really working well for me. Not that I'm comparing this to a strip show or anything like that...given I don't know what happens in a strip show anyway...
billybunter
Postby billybunter » Thu Oct 06, 2011 8:05 pm
will carry on .........with the tease. wait till we get to the interior. had this door jam rubber the wrong way in, just change it over. old photo here showing wrong direction
billybunter
Postby billybunter » Fri Oct 07, 2011 4:45 pm
now it's onto the side skirts
billybunter
Postby billybunter » Sun Oct 09, 2011 5:17 pm
davidau
Postby davidau » Sun Oct 09, 2011 6:06 pm
Red to go fast?
The progress is good.
What type of paint do you use for door card?
billybunter
Postby billybunter » Sun Oct 09, 2011 6:19 pm
3m vinyl paint - you can get it at supercheap and goes straight on. should be a good product being 3M. one thing you must do is prepare the surface well with grease/wax remover.
i cleaned the panel parts several times. literally laid it on. when on to the painting still got grease bubbles on a couple of parts. best thing to do is out with the g/w remover again and wipe over the contaminated area. after that just blend the red paint into the black.
allowed 10 to 20 minutes per coat. three coats in all.
don't slap it on thick or this stuff will run easily.
Guran
- Vehicle: ND - 1.5
Postby Guran » Sun Oct 09, 2011 6:28 pm
How good is that cleaner at removing Armorall and similar silicone-based vinyl treatments? I've been told they can be virtually impossible to get off, and cause delamination of overpaint. Probably more of an issue for exterior panels. Hope you don't have that problem.
Standard 2006 NC -
YouTubeWP 1:11.89 | SMP-S 1:05.90 GP 1:54.93 N 1:18.09 L 2:22.49 | PW 1:02.52
