I recently bought a nice NA with an aftermarket JVC stereo. Recently, for no reason I can see, it started flashing PROTECT on the screen and won't do anything. I've tried disconnecting the battery and it worked for a couple of minutes then started flashing PROTECT again.
Any ideas how I could fix it?
Thanks in advance for any help
Stereo saying protect?
Re: Stereo saying protect?
It means someone didnt know what they were doing or cut corners fitting it. Its shorted out somewhere, take it to your local professional car audio shop and have them find the wiring fault and fix it properly.
I work at JB HiFi in car sound, and see this all the time, thats why we offer fitting as a service.
- de Bounce
The protection circuit is activated in the audio output stage.
It is made to protect the amp from shorted speakers or shorted speaker wires.
A common cause is a strand of copper from one of your speaker wires is touching across to another binding post.
Check that your speaker wires are not shorting out and that the speakers are good.
- Jeo
You have a shorted wire somewhere. Best of luck finding it!
- muzzy66
If none of the above, then check how your speakers have been wired up. The installer may have done something dodgy like wire the front and rear speakers up in parallel - assuming they are 4ohm speakers, this would that cause them to draw a 2ohm load on the head units built in amp which could cause it to go into protect.
Car
2004 Alfa Romeo 147 GTA
Audio
Source: Clarion HX-D2
Speakers: Focal 165WRC
Amp: Zapco Reference 350.2
Sub: DLS Nordica 10i
Amp: Helix H1000
Car
Audio
Amp: Helix H1000
Thanks for the help guys. I'll have a look at the wiring tomorrow and see what I can see. Wiring is my least favorite thing part of cars. Sigh.
Users browsing this forum: No registered users and 43 guests
