Used Clutch on Freshly Machined Flywheel
CheyneX5
Postby CheyneX5 » Wed Sep 28, 2011 1:24 pm
Good day all,
Just curious as to how this should work... When my motor was swapped, they kept the old clutch in but machined a standard flywheel, the clutch did have a little sheen to it and couple of small heat spots. Now, over time, under hard acceleration, it feels a little rough. It is as though the clutch is slipping ever so slightly. Acceleration feels smoother and better on half throttle. If i flick the car into neutral and go through the rev range, it's smooth as caramel.
Also, the standard kick back on deceleration feels a little laggy and delayed, almost like something is sticking... There is also a squeaking noise coming from the back of then engine bay that will go away when pressure is applied to the clutch pedal.
90' NA6 - Classic Red
taminga16
Re: Used Clutch on Freshly Machined Flywheel
Postby taminga16 » Wed Sep 28, 2011 2:05 pm
Cheyne,
YOU NEED A DISTRACTION, Get a girl and just drive the car!
Greg. :)
sailaholic
Postby sailaholic » Wed Sep 28, 2011 2:58 pm
Squeak is the spigot bearing
CheyneX5
Postby CheyneX5 » Wed Sep 28, 2011 3:05 pm
Haha, thanks Greg. Got the girl. Car is still very fun to drive, no worries there, just wanted some advice.
taminga16
Postby taminga16 » Wed Sep 28, 2011 3:14 pm
Hi Cheyne,
I too would lean toward the Spigot bearing (bush?) and the fix would require gearbox removal, I had an old Holden once and it only squeaked on cold days, the bush was a non ferrous lubricant filled alloy and the lube only worked once it was warm.
Good luck.
Greg.
GP
Postby GP » Wed Sep 28, 2011 3:33 pm
Or throwout bearing :D
Graham
CheyneX5
Postby CheyneX5 » Wed Sep 28, 2011 3:34 pm
Yeah, sounds about right. I'm not so concerned about the noise though, more what is going on with the clutch/flywheel.
Dweezle
Postby Dweezle » Wed Sep 28, 2011 4:13 pm
The squeaking noise if it sounds like crickets, could be the slave cylinder pushrod touching the clutch arm.
Needs a lil grease to shut it up.
Sent from my GT-P1000 using Tapatalk
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Postby Mr Morlock » Wed Sep 28, 2011 5:08 pm
not sure about the descriptions you are giving. Might just be easier to get a mechanic to test drive it eg MX5 factory or someone you know. If the clutch is slipping it usually pretty easy to reproduce- eg handbrake on release clutch- select high gear on a steep hill ie make the car lug etc.
Users browsing this forum: No registered users and 139 guests
