Ohlins, OMG!!
Sailor
Ohlins, OMG!!
Postby Sailor » Tue Sep 27, 2011 7:19 pm
I bit the bullet a month back when the dollar was at its apogee, and while GWR had a special on, and bought a set of Ohlin DFV for my NC.
Installed them today.
I thought I had a great ride with my std springs and Tokico HTS adjustables, and it is compared to the std suspension, BUT the Ohlins are absolutely amazing!!
The car is taught but still compliant enough to take speed humps at speed without crashing or leaping around.
Turn in is so fast it's almost frightening! :shock:
I'd heard the reports from people with them including Brian Goodwin but I was still dubious about the extra cost over the many other coilovers that are around....Could they be THAT good?
They are...and well worth the extra. :D
Rob
Hjt
Re: Ohlins, OMG!!
Postby Hjt » Tue Sep 27, 2011 8:21 pm
Do glad they worked out for you, did you have to keep the stock tophats or fcm bump stops, or was the units complete?
Re: Ohlins, OMG!!
Postby orx626 » Tue Sep 27, 2011 8:56 pm
I concur Sailor! 8) I have them on my RX-8 and after previously having Tein Super Streets there is a very clear margin between their performance. Enjoy!
ps. I also have a new set for my NC race car which I can't wait to experience once it finally turns a wheel under its own power.
mx52nv
Purple Porsche Eater
Re: Ohlins, OMG!!
Postby mx52nv » Tue Sep 27, 2011 9:02 pm
Sailor wrote:I bit the bullet a month back when the dollar was at its apogee, and while GWR had a special on, and bought a set of Ohlin DFV for my NC.
I've been saying this for years now and now at least two NC owners are backing me up. :mrgreen:
Les
Sailor
Re: Ohlins, OMG!!
Postby Sailor » Tue Sep 27, 2011 9:16 pm
Hjt wrote:Do glad they worked out for you, did you have to keep the stock tophats or fcm bump stops, or was the units complete?
Required the stock tophats and associated bushes only.
After I get things sorted I'll see if a different set of bumpstops are required...somehow, after initial impressions, I doubt it. :)
Danny/Les....I'm a believer!!
Rob
Apu
Re: Ohlins, OMG!!
Postby Apu » Tue Sep 27, 2011 10:19 pm
Doesn't surprise me. I took part in a focus group for another leading Euro brand years ago, and on the quiet, the rep admitted Ohlins was the benchmark.
Re: Ohlins, OMG!!
Postby Regie » Wed Sep 28, 2011 3:00 pm
i think you might have to take me for a drive :P
kris
Re: Ohlins, OMG!!
Postby kris » Wed Sep 28, 2011 7:09 pm
Awesome, Installing mine, finally , this week :)
scud
Re: Ohlins, OMG!!
Postby scud » Fri Oct 28, 2011 1:37 pm
Are there any reviews here of Ohlins being run in na/nb cars???
Given the wrap they are getting I may just hold out extra long and go for these on my na over the ground control koni kit...
deanb90
Re: Ohlins, OMG!!
Postby deanb90 » Fri Oct 28, 2011 2:00 pm
I would of loved to get ohlins, but couldn't afford it.
So i settled with BC gold series, the improvement over stock is nothing short of sensational.
kris
Re: Ohlins, OMG!!
Postby kris » Fri Oct 28, 2011 2:29 pm
Love my Ohlins..... dollar is creeping up against the greenback again fellas.....
Sailor
Re: Ohlins, OMG!!
Postby Sailor » Fri Oct 28, 2011 2:42 pm
Hey Kris what settings are you using on the road now?
I've backed the fronts off to 10 and the rears to 14 (unloaded).
Will try the fronts at 12 next week.
BTW 7 F&R is too soft for the track but you can just drive over all the ripple strips without the car stepping offline.
I can't see this getting dramatically worse with firmer settings, the DFV system works!
Rob
kris
Re: Ohlins, OMG!!
Postby kris » Fri Oct 28, 2011 2:56 pm
Awesome,
I've got fronts on full minus 10 clicks and the back on full minus 12 clicks.
I have only tried running them 2-5 clicks back from full hard (recommended by US track guys) for a few days as the roads around here are pretty bad..... can't wait to try them on the track, were you pleasantly surprised over the weekend?
I haven't cleaned up the holes in my strut tower brace yet.... (hopefully i get around to it) but i don't have to use the supplied allan key.
Next time i got to get a better look at your car in the daylight! Especially want to check out your PF01s :)
Sailor
Re: Ohlins, OMG!!
Postby Sailor » Wed Jan 18, 2012 5:01 pm
Damn looks like these things are becoming common...Well done you! 8)
BTW I now have mine set at 22 F and 24R around Sydney streets for commuting
Probably a tad under damped but nice ride.
Dear has noticed that the car "turns quicker" but hasn't mentioned anything about the springs being much firmer so shock settings are pretty close.
Front bar is on the softest setting and rear is in the middle.
Only problem is that on some driveways the inside rear wheel lifts off the deck but the car is beautifully balanced.
Rob
Guy_Coles
Re: Ohlins, OMG!!
Postby Guy_Coles » Wed Jan 18, 2012 7:56 pm
Sailor wrote:Damn looks like these things are becoming common...Well done you! 8)
Well you've convinced me ! Mine were ordered today.
Maybe we need to set up a separate thread called Ohlins Street/Track settings and compare notes !
Guy
2006 Black NC Soft Top with lots of Mods -
WP: 1:12.26 , SMP South 1:106.25 - 11th outright in Victorian 6 Hour 2015
http://privasec.com.au//
