idle problem when warm
mr bender
Postby mr bender » Sun Sep 11, 2011 6:24 pm
hello
First of all i have read throught the forum and cant find a answer.
It starts fine , runs fine no missing or anything but it idles at 2000 rpm
I have replaced the Idle Speed Control Valve , throttle body and the Air Valve still no luck
It is a NA 1.6 turbo with a plug and play wolf 3D.
It use to idle before and i havent change the tune or anything.
its not the BOV , intercooler pipes , intercooler , broken hose etc.
i have tryed all i can think off so hopefully iv missed something and you guys can tell me what it is!!!
Thanks
Glen
Re: idle problem when warm
Postby manga_blue » Sun Sep 11, 2011 7:26 pm
Not sure what your Wolf does but the stock ECU used TPS closed switch (on the throttle body), gearbox neutral switch (on top of the gearbox), clutch switch (on top of the clutch pedal arm) and engine coolant temp sensor (at rear of cylinder head?) to determine idle speed.
mr bender
Postby mr bender » Sun Sep 11, 2011 8:54 pm
ok i will check them out thanks mate
also does anyone know if the wolf still uses the DIAGNOSIS box??
i want to try this but dont know if it will hurt the ecu
:http://www.miata.net/garage/KnowYourCar/S7_Idle.html
any idea?
buz 138
Postby buz 138 » Thu Sep 22, 2011 4:00 pm
triple check all vacume lines for holes/splits??
mr bender
Postby mr bender » Sun Sep 25, 2011 10:37 pm
I was wrong it was the BOV after i checked everything about 3 times!
It seem that the diaphragm has split and torn open from eather to much boost or it is just old.
thanks guys
Postby NitroDann » Sun Sep 25, 2011 10:51 pm
mr bender wrote:too much boost
Wimp.... :P
No. Such. Thing. :P
Users browsing this forum: No registered users and 152 guests
